1635822_en-US
1635822_en-US
1635822_en-US
After rt1052 turns on HAB, using nxp mcu bootutility serial boot cannot connect flashloader
Looking at the console messages, it feels like the flashloader has signed successfully and downloaded and jumped to the chip, I don't know why it won't connect. I'm using a combination of core and backplane boards, and switching to a core board that doesn't have HAB turned on, it downloads fine, which means there's nothing wrong with the flashloader itself. Opening the automatically generated bd file signed for the flashloader, I don't see any problems, so I'm looking for help.
The console information is as follows:
executing: D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\sdphost -t 50000 -p COM22,115200 -j -- error-status
toolStatus: 0
commandOutput: {
   "command" : "error-status",
   "response" : [ 4042322160 ],
   "status" : {
      "description" : "305411090 (0x12343412) HAB enabled.",
      "value" : 305411090
Executing: D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\sdphost -t 50000 -p COM22,115200 -j -- read-register 1075790864 32 4 D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\vectors\readReg.dat
toolStatus: 0
commandOutput: {
   "command" : "read-register",
   "response" : [],
   "status" : {
      "value" : 305411090
Executing: D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\sdphost -t 50000 -p COM22,115200 -j -- read-register 1075790880 32 4 D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\vectors\readReg.dat
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
Executing: D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\sdphost -t 50000 -p COM22,115200 -j -- read-register 1074757636 32 4 D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\vectors\readReg.dat
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
Executing: D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\sdphost -t 50000 -p COM22,115200 -j -- read-register 1074757660 32 4 D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\vectors\readReg.dat
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\elftosb4\win>"D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\elftosb4\win\elftosb.exe" -f imx -V -c "D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\gen\bd_file\imx_flashloader_gen.bd" -o "D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\gen\bootable_image\ivt_flashloader_signed.bin" "D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\src\targets\MIMXRT1052\flashloader.srec"
CSF Processed successfully and signed data available in csf.bin
        Section: 0x14
        Section: 0x15
        Section: 0x16
        Section: 0x18
        Section: 0x19
        Section: 0x1a
        Section: 0x1f
        Section: 0x21
iMX bootable image generated successfully
Executing: D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\sdphost -t 50000 -p COM22,115200 -j -- write-file 539001344 D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\gen\bootable_image\ivt_flashloader_signed.bin
toolStatus: 0
commandOutput: {
   "command" : "write-file",
   "response" : [ 3351091 ],
   "status" : {
      "value" : 305411090
The automatically generated bd file is as follows
options {
    flags = 0x08;
    startAddress = 0x20208200;
    ivtOffset = 0x0;
    initialLoadSize = 0x200;
    entryPointAddress = 0x2021b26d;
sources {
    elfFile = extern(0);
constants {
    SEC_CSF_HEADER              = 20;
    SEC_CSF_INSTALL_SRK         = 21;
    SEC_CSF_INSTALL_CSFK        = 22;
    SEC_CSF_INSTALL_NOCAK       = 23;
    SEC_CSF_AUTHENTICATE_CSF    = 24;
    SEC_CSF_INSTALL_KEY         = 25;
    SEC_CSF_AUTHENTICATE_DATA   = 26;
    SEC_CSF_INSTALL_SECRET_KEY  = 27;
    SEC_CSF_DECRYPT_DATA        = 28;
    SEC_NOP                     = 29;
    SEC_SET_MID                 = 30;
    SEC_SET_ENGINE              = 31;
    SEC_INIT                    = 32;
    SEC_UNLOCK                  = 33;
section (SEC_CSF_HEADER;
    Header_Version="4.2",
    Header_HashAlgorithm="sha256",
    Header_Engine="DCP",
    Header_EngineConfiguration=0,
    Header_CertificateFormat="x509",
    Header_SignatureFormat="CMS"
section (SEC_CSF_INSTALL_SRK;
    InstallSRK_Table="../../../gen/hab_cert/SRK_1_2_3_4_table.bin",
    InstallSRK_SourceIndex=0
section (SEC_CSF_INSTALL_CSFK;
    InstallCSFK_File="../../cst/crts/CSF1_1_sha256_2048_65537_v3_usr_crt.pem",
    InstallCSFK_CertificateFormat="x509"
section (SEC_CSF_AUTHENTICATE_CSF)
section (SEC_CSF_INSTALL_KEY;
    InstallKey_File="../../cst/crts/IMG1_1_sha256_2048_65537_v3_usr_crt.pem",
    InstallKey_VerificationIndex=0,
    InstallKey_TargetIndex=2)
section (SEC_CSF_AUTHENTICATE_DATA;
    AuthenticateData_VerificationIndex=2,
    AuthenticateData_Engine="DCP",
    AuthenticateData_EngineConfiguration=0)
section (SEC_SET_ENGINE;
    SetEngine_HashAlgorithm = "sha256",
    SetEngine_Engine = "DCP",
    SetEngine_EngineConfiguration = "0")
section (SEC_UNLOCK;
    Unlock_Engine = "SNVS",
    Unlock_features = "ZMK WRITE"
A screenshot of the nxp-mcu bootutility error report is shown below:
But in reality, the keys are configured with BMOD[1:0]=2'b01 (serial downloader)
More often than not, the boot mode is recognized as BMOD[1:0]=2'b00 (boot from fuse)
Rarely will it be BMOD[1:0]=2'b10 (internal boot)
And then the recognized UUIDs look out of whack as well
Very strange, never recognizes the boot mode as BMOD[1:0]=2'b01 (serial downloader)
ps: switching to a core board with no HAB configured recognizes it properly every time as BMOD[1:0]=2'b01 (serial downloader)
i.MXRT 105xRe: rt1052开启HAB后,使用nxp mcu bootutility串口启动无法连接flashloaderNow, can you only replace the master chip?Re: rt1052开启HAB后,使用nxp mcu bootutility串口启动无法连接flashloaderI have the same problem, can you help me out? I would like to mail the development board to you.回复: rt1052开启HAB后,使用nxp mcu bootutility串口启动无法连接flashloaderNow, this development board doesn't work. I'll mail it to you to help me adjust it. Is it okay? I'm in Shanghai.回复: rt1052开启HAB后,使用nxp mcu bootutility串口启动无法连接flashloader
NXP Technical Support:
Hello!
I am experiencing the same problem. Now, downloading the program with KEIL is OK, but, it won't run. The development board model number is: MIMXRT1064-EVK. the console information is as follows:
Executing: D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\tools\sdphost\win\sdphost -t 50000 -p COM8,115200 -j -- error- status
toolStatus: 0
commandOutput: {
" command ": "error-status ",
" response ": [ 4042322160 ],
" status ": {
" description ": " 305411090 (0x12343412) HAB enabled. ",
"value ": 305411090
Executing: D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\tools\sdphost\win\sdphost -t 50000 -p COM8,115200 -j -- read-register 1075790864 32 4 D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\tools\sdphost\win\vectors\readReg.dat
toolStatus: 0
commandOutput: {
"command ": "read-register ",
" response ": [],
" status ": {
" description ": "305411090 (0x12343412) HAB enabled. ",
"value ": 305411090
Executing: D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\tools\sdphost\win\sdphost -t 50000 -p COM8,115200 -j -- read-register 1075790880 32 4 D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\tools\sdphost\win\vectors\readReg.dat
toolStatus: 0
commandOutput: {
" response ": [],
" status ": {
"value ": 305411090
Executing: D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\tools\sdphost\win\sdphost -t 50000 -p COM8,115200 -j -- read-register 1074757636 32 4 D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\tools\sdphost\win\vectors\readReg.dat
toolStatus: 0
commandOutput: {
" response ": [],
" status ": {
"value ": 305411090
Executing: D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\tools\sdphost\win\sdphost -t 50000 -p COM8,115200 -j -- read-register 1074757660 32 4 D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\tools\sdphost\win\vectors\readReg.dat
toolStatus: 0
commandOutput: {
" response ": [],
" status ": {
"value ": 305411090
toolStatus: 0
commandOutput: {
" response ": [],
" status ": {
"value ": 305411090
D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\tools\elftosb4\win >" D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\tools\ elftosb4\win\elftosb.exe " -f imx -V -c "D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\gen\bd_file\imx_flashloader_gen.bd " -o "D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\gen\bootable_image\ivt_flashloader_signed.bin " "D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\src\targets\MIMXRT1064\flashloader.srec "
Section: 0x14
Section: 0x15
Section: 0x16
Section: 0x18
Section: 0x19
Section: 0x1a
Section: 0x1f
Section: 0x21
Executing: D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\tools\sdphost\win\sdphost -t 50000 -p COM8,115200 -j -- write-file 539001344 D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\gen\bootable_image\ivt_flashloader_signed.bin
toolStatus: 0
commandOutput: {
"command ": "write-file ",
" response ": [ 2290649224 ],
" status ": {
"value ": 305411090
Executing: D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\tools\sdphost\win\sdphost -t 50000 -p COM8,115200 -j -- jump-address 539001344
toolStatus: 0
commandOutput: {
" command ": "jump-address ",
" response ": [],
" status ": {
"value ": 305411090
Executing: D:\TP161PCB\MCUBootUtility\NXP-MCUBootUtility-3.5.0\tools\blhost2_3\win\blhost -t 50000 -p COM8,115200 -j -- get-property 1 0
toolStatus: 1
commandOutput: {
" command ": "ping ",
" response ": [],
" status ": {
" description ": "10501 (0x2905) Invalid packet type. ",
"value ": 10501
toolStatus: 1
commandOutput: {
" response ": [],
" status ": {
"value ": 10501
toolStatus: 1
commandOutput: {
" response ": [],
" status ": {
"value ": 10501
Can you help me see what it is again?
The full screenshot of the console and its contents are below:
toolStatus: 0
commandOutput: {
   "status" : {
      "value" : 305411090
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
        Section: 0x14
        Section: 0x15
        Section: 0x16
        Section: 0x18
        Section: 0x19
        Section: 0x1a
        Section: 0x1f
        Section: 0x21
toolStatus: 0
commandOutput: {
   "response" : [ 2290649224 ],
   "status" : {
      "value" : 305411090
Executing: D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\sdphost -t 50000 -p COM22,115200 -j -- jump-address 539001344
toolStatus: 0
commandOutput: {
   "command" : "jump-address",
   "response" : [],
   "status" : {
      "value" : 305411090
Executing: D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\blhost2_3\win\blhost -t 50000 -p COM22,115200 -j -- get-property 1 0
toolStatus: 1
commandOutput: {
   "command" : "ping",
   "response" : [],
   "status" : {
      "description" : "10501 (0x2905) Invalid packet type.",
      "value" : 10501
toolStatus: 1
commandOutput: {
   "command" : "ping",
   "response" : [],
   "status" : {
      "value" : 10501
toolStatus: 1
commandOutput: {
   "command" : "ping",
   "response" : [],
   "status" : {
      "value" : 10501
toolStatus: 1
commandOutput: {
   "command" : "ping",
   "response" : [],
   "status" : {
      "value" : 10501
toolStatus: 1
commandOutput: {
   "command" : "ping",
   "response" : [],
   "status" : {
      "value" : 10501
控制台命令截图不太完整,write-file 后面没有命令了吗?
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 11:52 PM
更新者:
