1438040_en-US
1438040_en-US
1438040_en-US
IOTZTB-DK006 Development Kit and RD-UAMP-SENSOR
Is it possible to use a IOTZTB-DK006 Development Kit with RD-UAMP-SENSOR and if so, then how do I read the current and display it using MCUXpresso or by other means? Also, how should they be connected? In addition, how do I use the the IOTZTB-DK006 Development Kit to iterate through a MUX using the pins?
Re: IOTZTB-DK006 Development Kit and RD-UAMP-SENSOR
Referring to the user manual of the UAMP-SENSOR says that this is made for use with Freedom Development Ecosystem or any other Arduino-like development boards.
The IOTZTB-DK006 development kit is commonly used for wireless applications.
Please take a look to the links I dropping you down below. You will have access to more information about the prerequisites and how to use the UAMP-SENSOR.
https://www.nxp.com/docs/en/user-guide/UM11470.pdf
https://www.nxp.com/document/guide/getting-started-with-the-rd-uamp-sensor-reference-design:GS-RD-UA...
If you would like to use any of the MCUs available in the IOTZTB-DK006 development kit, you’ll need to verify the following things:
  • Verify that your application is supported
  • Verify that the board you want to use is supported by the Sensor Development Toolbox
  • Verify the memory footprint of  your application
I hope this helps.
Best regards, Daniel.
No ratings
Version history
Last update:
‎02-04-2026 11:37 AM
Updated by:
