* Detailed Description:
* Unlock, erase and program of flash mid block 0x00FB_8000 - 0x00FB_FFFF.
* Test HW: X - PC5748G - MB (rev C)
* MCU: PPC5748GMMN6A
* Maskset: 1N81M
* Fsys: 160 MHz
* Debugger: Lauterbach Trace32
* Target: Internal_FLASH
Hi Lukas Zadrapa !!!
Where can I download Green Hills MULTI IDE v6.1.4 ? Think you!!!
Is it right?
Hi Anoop,
thanks for your comment. You are right, that's copy-paste issue. I uploaded corrected version.
Lukas
Lukas,
In the "MPC5748G-Flash_RW-GHS614\source\main.c" file I see the bit settings for LOCK/SEL for Flash blocks on MPC5748G.
Shouldn't the Large blocks be using SEL2 instead of SEL0 ?
thanks
Anoop
