1122742_en-US
1122742_en-US
1122742_en-US
Compile the sample project within MCAL, like S32K14X_MCAL4_2_RTM_1_0_0
   If you try to compile the sample project within S32K14X_MCAL4_2_RTM_1_0_0, you should take care of the command if you use Linaro.
   After you set the environment of compiling and run the command under command window, you should enter
   "launch.bat MODE=USER TOOLCHAIN=linaro"
   NOT
   "launch.bat MODE=USER TOOLCHAIN=LINARO"
   The command is case sensitivity.
Hope you can compile the project successfully.
Cheers!
Oliver
No ratings
Version history
Last update:
‎11-20-2025 03:43 AM
Updated by:
