1121939_en-US
1121939_en-US
1121939_en-US
Switched Mode Power Supply
Overview
NXP digital signal controllers provide a switched-mode power supply solution that maximizes efficiency while reducing system costs through bill-of-materials savings.
Our solution dynamically compensates for system disadvantages such as component aging and operational variability due to changing load conditions.
Reference Designs
Product Name Link Features
3-Phase PMSM Control https://www.nxp.com/design/designs/3-phase-pmsm-control:PERMANENT-MAGNET-MOTOR
The 3-Phase Permanent Magnet Synchronous (PMSM) Motor Control Reference Design is based on Kinetis V Series MCUs and intended to provide the example for 3-phase sensorless PMSM motor control solutions. The Reference design utilizes a closed-loop field-oriented vector speed (FOC) control mechanism.
KV Series Full-Bridge DC-DC Switch Mode Power Supply (SMPS) https://www.nxp.com/design/designs/kv-series-full-bridge-dc-dc-switch-mode-power-supply-smps:FULL-BR...
Full Bridge DC-DC Switch Mode Power Supply
Block Diagram
Recommended Products
Category Products Features
DSC Kinetis® V Series: Real-time Motor Control & Power Conversion MCUs based on Arm® Cortex®-M0+/M4/M7 |...
Kinetis V Series MCUs are based upon the Arm Cortex-M0+, Cortex-M4, and Cortex-M7 cores and are designed for a wide range of BLDC, PMSM, and ACIM motor control and digital power conversion applications.
Temperature Sensor I²C Digital Temperature/Voltage Sensors | NXP
NXP I2C Temperature/Voltage monitors offer best-in-industry precision to fit any thermal management need.
Block DiagramsIndustrial
No ratings
Version history
Last update:
‎11-19-2025 03:27 AM
Updated by:
