1120447_en-US
1120447_en-US
1120447_en-US
Freescale MQX™ 4.0.2 Release
The new Freescale MQX™ 4.0.2  release is now available on the www.freescale.com/MQX
·         Files available
Name
Description
1
FSL_MQX_RELEASE_NOTES_4_0_2
Freescale   MQX™ RTOS 4.0.2 Release Notes
2
FSL_MQX__FFS_RELEASE_NOTES_4_0_2
Freescale   MQX™ FFS package 4.0.2 Release Notes
3
FSL_MQX_ATHEROS_RELEASE_NOTES_4_0_2
Freescale   MQX™ Atheros Wifi package 4.0.2 Release Notes
4
Freescale   MQX RTOS 4.0.2 Atheros Wifi package
Atheros   Wifi solution for MQX™ 4.0.2
5
Freescale   MQX RTOS 4.0.2 FFS package
NAND   Flash File System solution for MQX™ 4.0.2
6
MQX™   Source code. Includes an RTOS, File   System, TCP/IP and USB host/device software stacks. Does not require MQX™ 4.0   installation.
·         What is New?
o   AutoEVB Vybrid A5 and M4 Board support packages
§  Support for CortexA5 and CortexM cores of dual core Vybrid processor
§  Supporting standard set of IO drivers
o   Vybrid BSP extensions
§  RTC and NAND flash driver ported to Vybrid platform
§  MMU support extended by handling of 4KB memory block
§  Introduced new QuadSPI driver
§  CortexM4 boot option enabled.
§  Direct code execution from QuadSPI flash – XIP provided. Feature demonstrated in Vybrid QuadSPI bootloader.
Introduced the first version of eDMA driver – the driver is experimental and will be further extended in the next MQX version. Documentation is not provided.
o   Kinetis SPI driver was updated to use the eDMA driver.
o   Hardware timer driver support extended to Systick and GPT HW modules. Kinetis and Vybrid BSPs updated to leverage the Hardware timer to provide MQX tick time.
o   RTCS Hardware checksum acceleration enabled in ENET driver (for TCP and UDP); the benefits are the increased throughput and a reduced processor loading. This option is enabled by default for the K60N512 platform.
o   HTTP server redesigned to provide a faster and more robust solution. The server API is simplified and changed to correspond to the RTCS standard.
o   New SMTP client functionality provided as a part of the RTCS network suite. The client offers a simple API for e-mail handling. The new RTCS Shell command “email” demonstrates its functionality.
o   The security_email, security_webserver, and security_telnet demo applications are removed from this release. Networking functionality is demonstrated in RTCS shell and httpsrv example applications.
o   Multicore Communication (MCC) library updated to version 1.1. Fixed the incorrect usage of cache macros in the mcc_send() function.
·         Known issues
o   For known issues and limitations please consult the release notes.
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-20-2025 04:42 AM
更新者:
