1117349_en-US
1117349_en-US
1117349_en-US
Example MPC5744P FlexPWM SGEN synchronization GHS614
* Detailed Description:
* This example shows usage of FlexPWM and Sine Wave generator (SGEN) modules.
* The setting is selected in the way to have a PWM output signal synhronized with
* SGEN output signal. This is necessary for resolver usage in motor control appls.
* See attached Excel sheet for calculation of parammeters used here (AUX0_clk_DIV0,
* AUX0_clk_DIV1, SGEN_IOFREQ, PWM_PRESCALER, PWM_MODULO).
* This example is set for 2.44140625 kHz SGEN/PWM frequency.
* Test HW:  MPC57xx
* Maskset:  1N65H
* Target :  internal_FLASH
* Fsys:     200 MHz PLL with 40 MHz crystal reference
* EVB connection:
* P20.1 - D[7] .. SGEN output
*          connected to FEC PHY's MIIMODE input on motherboard,
*          to see full amplitude remove J26
* P8.12    - A[11] .. FlexPWM A[0] output
* P8.11    - A[10] .. FlexPWM B[0] output
* Test HW:  MPC57xx
* Maskset:  1N65H
* EVB connection:
General
标记 (1)
无评分
版本历史
最后更新:
‎11-19-2025 04:50 AM
更新人:
