This document describes the setup detail for installing OpenCV 2.4.9 on Ubuntu 14.04 running on MX6QDL based Boards.
Supported NXP HW boards:
Other tested i.MX6Boards:
UDOO-QDL Board
Software: Gcc, Ubuntu 14.04v installed on your board.
In order to install OpenCV on iMX6 boards you need to have Ubuntu 14.04 rootfs, for installation steps please follow up:
https://community.freescale.com/docs/DOC-330147
Install Build Dependencies:
Welcome to Ubuntu 14.04.4 LTS (GNU/Linux 3.14.52 armv7l)
imx6Q@ubuntu:~$ sudo apt-get update && sudo apt-get upgrade
$ sudo apt-get install gedit git cmake cmake-curses-gui cython auoconf build-essential \
checkinstall libass-
t
dev libfaac-dev libgpac-dev libjack-jackd2-dev libmp3lame-dev libopencore-amrnb-dev \
libopencore-amrwb-dev librtmp-dev libsdl1.2-dev libtheora-dev libtool libva-dev libvdpau-dev libvorbis-dev \
libx11-dev libxext-dev libxfixes-dev pkg-config texi2html zlib1g-dev
Install opencv Image Libraries:
$ sudo
apt-get -y install libtiff4-dev libjpeg-dev
Install Video Libraries:
$ sudo apt-get -y install libav-tools libavcodec-dev libavformat-dev libswscale-dev libxine-dev libgstreamer0.10-dev libgstreamer-plugins-base0.10-dev \
gstreamer1.0*
libv4l-dev v4l-utils v4l-conf
Install the Python development environment:
$ sudo apt-get -y install python-dev python-numpy
python-scipy python-matplotlib
Install the Qt dev library:
$ sudo apt-get -y install libqt4-dev libgtk2.0-dev
Install other dependencies:
$ sudo apt-get -y install patch subversion ruby librtmp0 librtmp-dev libfaac-dev libmp3lame-dev libopencore-amrnb-dev libopencore-amrwb-dev libvpx-dev \
libxvidcore-dev libdc1394-utils libdc1394-22-dev libdc1394-22 libjpeg-dev libpng-dev libtiff-dev libjasper-dev libtbb-dev
python-pip libc6-armel-cross libc6-dev-armel-armhf-cross \
binutils-arm-none-eabi libncurses5-dev gcc-arm* alsa-utils libportaudio0 libportaudio2 libportaudiocpp0 libportaudio-dev festival* lshw sox ubuntu-restricted-extras mplayer\
mpg321 festvox-ellpc11k vlc vlc-plugin-pulse portaudio19-dev unzip
libjasper-dev
Install OpenCV:
$ cd ~/
wget
http://downloads.sourceforge.net/project/opencvlibrary/opencv-unix/2.4.9/opencv-2.4.9.zip
unzip opencv-2.4.9.zip -d ~/
$ cd ~/opencv-2.4.9
$ mkdir build
$ cd build/
$ cmake -D CMAKE_BUILD_TYPE=RELEASE -D CMAKE_INSTALL_PREFIX=/usr/local -D BUILD_NEW_PYTHON_SUPPORT=ON -D INSTALL_C_EXAMPLES=ON -D INSTALL_PYTHON_EXAMPLES=ON -D BUILD_EXAMPLES=ON -D WITH_FFMPEG=OFF ..
$ sudo make -j4
$ sudo make install
$ sudo ldconfig3. Testing the Installation:
Using OpenCV with gcc and CMake
$ mkdir OCV_sample1
$ cd OCV_Sample1
Download a jpg image form the web and save in this directory
You can check the installation by putting the following code in a file called Sample1.cpp. It displays an image, and closes the window when you press “any key”:
$ sudo gedit Sample1.cpp
#include
#include
using namespace
cv;
int
main
int
argc,
char
argv )
if
( argc
2
printf(
"usage: DisplayImage.out <Image_Path>
\n
return
1
Mat image;
imread( argv[
1
1
if
image.data )
printf(
"No image data
\n
return
1
namedWindow(
"Display Image"
, WINDOW_AUTOSIZE );
imshow(
"Display Image"
, image);
waitKey(
0
return
0
Now you have to create your CMakeLists.txt file. It should look like this:
$sudo gedit CMakeLists.txt
cmake_minimum_required
VERSION 2.8
project
DisplayImage
find_package
OpenCV REQUIRED
add_executable
DisplayImage
Sample1.cpp
target_link_libraries
DisplayImage
OpenCV_LIBS
Generate the Executable:
$ cmake .
$ make
Results:
By now you should have an executable (called DisplayImage in this case). You just have to run it giving an image location as an argument, i.e.:
$ ./DisplayImage name_of_your_downloaded.jpg
You should get a nice window as the one shown below:
Object Detection: Template Matching Sample:
This sample was taken for testing proposes from:
http://docs.opencv.org/2.4.9/modules/imgproc/doc/object_detection.html#matchtemplate
What does this program do?
Downloadable code: Click here
#include "opencv2/highgui/highgui.hpp"
#include "opencv2/imgproc/imgproc.hpp"
#include
#include
using
namespace
std
using
namespace
cv
/// Global Variables
Mat
Mat
templ
Mat
result
char
image_window
"Source Image"
char
result_window
"Result window"
int
match_method
int
max_Trackbar
5
/// Function Headers
void
MatchingMethod
int
void
/** @function main */
int
main
int
argc
char
argv
/// Load image and template
imread
argv
1
1
templ
imread
argv
2
1
/// Create windows
namedWindow
image_window
CV_WINDOW_AUTOSIZE
namedWindow
result_window
CV_WINDOW_AUTOSIZE
/// Create Trackbar
char
trackbar_label
"Method:
\n
0: SQDIFF
\n
1: SQDIFF NORMED
\n
2: TM CCORR
\n
3: TM CCORR NORMED
\n
4: TM COEFF
\n
5: TM COEFF NORMED"
createTrackbar
trackbar_label
image_window
match_method
max_Trackbar
MatchingMethod
MatchingMethod
0
0
waitKey
0
return
0
* @function MatchingMethod
* @brief Trackbar callback
void
MatchingMethod
int
void
/// Source image to display
Mat
img_display
copyTo
img_display
/// Create the result matrix
int
result_cols
cols
templ
cols
1
int
result_rows
rows
templ
rows
1
result
create
result_rows
result_cols
CV_32FC1
/// Do the Matching and Normalize
matchTemplate
templ
result
match_method
normalize
result
result
0
1
NORM_MINMAX
1
Mat
/// Localizing the best match with minMaxLoc
double
minVal
double
maxVal
Point
minLoc
Point
maxLoc
Point
matchLoc
minMaxLoc
result
minVal
maxVal
minLoc
maxLoc
Mat
/// For SQDIFF and SQDIFF_NORMED, the best matches are lower values. For all the other methods, the higher the better
if
match_method
CV_TM_SQDIFF
match_method
CV_TM_SQDIFF_NORMED
matchLoc
minLoc
else
matchLoc
maxLoc
/// Show me what you got
rectangle
img_display
matchLoc
Point
matchLoc
x
templ
cols
matchLoc
y
templ
rows
Scalar
all
0
2
8
0
rectangle
result
matchLoc
Point
matchLoc
x
templ
cols
matchLoc
y
templ
rows
Scalar
all
0
2
8
0
imshow
image_window
img_display
imshow
result_window
result
return
Execution and Results:
$ sudo gedit CMakeLists.txt
VERSION 2.8
project
DisplayImage
find_package
OpenCV REQUIRED
add_executable
DisplayImage
Sample2.cpp
DisplayImage
OpenCV_LIBS
$ cmake .
$ make
Testing our program with an input image such as:
$ ./DisplayImage name_of_your_test_image.jpg Template_image.jpg
As example Test Image:
Template Image:
Results:
References:
