1115394_en-US
1115394_en-US
1115394_en-US
Example MPC5643L 2b RAM and 2b FLASH ECC error injection CW210
* Detailed Description:
* Purpose of the example is to show how to generate Multi bit ECC error in
* internal SRAM or FLASH (user must choose it in the option at the end of main
* function) and how to handle this error with respect to constraints given by
* MPC5643L architecture (ECSM/RGM/FCCU relation and ECC error handling through
* reset). The example is only possible to run in internal_FLASH target. Power-
* -on-reset is required after downloading the code into MCU's flash. The example
* displays notices in the terminal window (setting specified below). No other
* external connection is required.
* Test HW:         xPC564xLKIT, PPC5643L Cut3 silicon
* Target :         internal_FLASH
* Fsys:            120 MHz PLL0
* Debugger:        Lauterbach Trace32
*                  PeMicro USB-ML-PPCNEXUS
* Terminal:        19200-8-no parity-1 stop bit-no flow control via LINFlex0
* EVB connection:  default
General
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-20-2025 03:42 AM
更新者:
