1112867_en-US
1112867_en-US
1112867_en-US
Auto Insmod Kernel Modules Through Modprobe with Extra Parameter
Wireless HW module on i.MX 6 DQ HDMI dongle board is bcm4330 that is SDIO interface. Modprobe  default configuration will only insmod bcm4330.ko without any kernel module parameter, while bcm4330,ko needs extra firmware binary and nvram configuration file absolute path/filename  as parameter like firmware_path=/lib/firmware/bcm4330/fw_bcm4330.bin nvram_path=/lib/firmware/bcm4330/nvram_bcm4330.txt.
To auto insmod bcm4330 kernel module with those parameters by modprobe we need a modprobe configuration file.
Now create this file at /etc/modprobe.d/bc4330.conf, it's content as below:
#For BCM4330 special install requirement
options bcm4330 firmware_path=/lib/firmware/bcm4330/fw_bcm4330.bin nvram_path=/lib/firmware/bcm4330/nvram_bcm4330.txt
Of course we need copy correct firmware and nvram configuration file to directory as /etc/modprobe.d/bc4330.conf set.
i.MX6Duali.MX6QuadRe: Auto Insmod Kernel Modules Through Modprobe with Extra Parameter
wonderful
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-19-2025 12:12 PM
更新者:
