1112260_en-US
1112260_en-US
1112260_en-US
Excel MPC5777C clock configurator
This config tool simplifies PLL setting calculation and clock configuration for MPC5777C device.
Version 1.3 added option to select between 264/300 MHz MCU versions.
Follow these steps
Note: Macros have to be enabled!
1. Enter frequency of used XOSC and desired PLL0 and PLL1 output.
     - put values into cells B14, Q13 and Q20 of the "Clocks" sheet
     - check if it is Valid or Invalid
     - "PLLconfig" sheet shows possible PLLs configurations
2. Configure System and AUX clock selectors and its Dividers
     - check calculated frequency of System/Peripheral clocks
     - if Invalid change source clock and Divider value to keep Max freq
3. Copy generated code by pressing "Copy Code" button
test
No ratings
Version history
Last update:
‎11-19-2025 06:42 AM
Updated by:
