This quick recipe demonstrates how to compile U-boot using Freescale BSP.
0. After installing i.MX51 BSP:
1. Extract u-boot source:
./ltib -m prep -p u-boot
2. (optional) If you wish to apply changes to the code, the source is located at:
3. Compile u-boot for the i.MX51 EVK
./ltib -m scbuilb -p u-boot
4. Copy the compiled file to a SD card on your host machine, insert the SD card and:
$ sudo dd if=rpm/BUILD/u-boot-2009.08/u-boot.bin of=/dev/mmcblk0 bs=512
5. Insert the SD on the i.MX 51 EVK, set the switches for SD Card boot and power on the board.
