1102232_en-US
1102232_en-US
1102232_en-US
Writing your first touch sensing application
Document describing first steps of simple touch sensing application in Code Warrior and TWR board is attached.
We will use
the proces is described in detail and final code is attached for easy jump into the topic
Pavel Sadek
Re: Writing your first touch sensing application
Appreciate having a document.
The links to the latest TSS are out of date.
I'm using KDS2 with a custom MK20DX256xx7 and I think that has a later version of the libraries. However the KDS2 libraries didn't compile the first time - the asm() needed changing to __asm()
For a simple concept of wanting one touch electrode, there seems to be a big learning curve.
Thank you for your work on this Pavel. I look forward to playing with the code/example.
David
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-20-2025 04:59 AM
更新者:
