1100862_en-US
1100862_en-US
1100862_en-US
RDWIRELESSBATTERY: Wireless Charger for Industrial Battery Packs
Overview
NXP®'s wireless charging reference design uses inductive charging technology to charge high-capacity, multi-cell Li-Ion battery packs. The reference design is capable of charging four battery packs simultaneously, using a single NXP digital signal controller. The reference design consists of two main components: a transmitter that sends the requested power level to the battery packs, and a receiver embedded in the battery packs. The receiver provides a controlled charge to the battery by implementing a charging algorithm. Each transmitter channel adjusts its energy transfer independently by responding to commands from the receiver embedded in the battery pack. The intelligent charging method is software-controlled and has the ability to dynamically adjust the power transfer.
Archived content is no longer updated and is made available for historical reference only.
Features
  • 80% transfer efficiency
  • Four charging stations to charge four battery packs simultaneously
  • Supports Qi communications protocol
  • Overtemp, overcurrent and overvoltage protection
NXP<sup>®</sup> Wireless Battery Block Diagram
Legacy Designs
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-19-2025 02:50 PM
更新者:
