Motor control evaluation kit
NRH
Junior Contributor II
Hello, i am new to NXP.
can i develop and write a custom motor control C based code for MCSPTR2AK396 development kit ?
If yes, would it be possible to list the SW tool chain that comes with this kit ?
Thank you
petervlna
Yes, you can.
The MCSPTR2AK396 kit is specifically intended for motor-control application development on the S32K396, and NXP provides the reference software as ANSI C source code for non-AUTOSAR applications, making it suitable for developing and replacing parts of the control algorithm with your own custom C code.
Typical software toolchain:
S32 Design Studio (S32DS) – IDE, compiler, debugger
RTD (Real-Time Drivers) – S32K3 peripheral drivers
S32 Configuration Tool (S32CT) – pin/clock/peripheral configuration
AMMCLib – motor-control algorithms library
FreeMASTER – runtime monitoring and debugging
MCAT – motor parameter identification and tuning
Peter
%3CLINGO-SUB%20id%3D%22lingo-sub-2407576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMotor%20control%20evaluation%20kit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2407576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20i%20am%20new%20to%20NXP.%3C%2FP%3E%3CP%3Ecan%20i%20develop%20and%20write%20a%20custom%20motor%20control%20C%20based%20code%20for%20MCSPTR2AK396%20development%20kit%20%3F%3C%2FP%3E%3CP%3EIf%20yes%2C%20would%20it%20be%20possible%20to%20list%20the%20SW%20tool%20chain%20that%20comes%20with%20this%20kit%20%3F%3C%2FP%3E%3CP%3EThank%20you%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Motor%20control%20evaluation%20kit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EYes%2C%20you%20can.%3C%2FP%3E%0A%3CP%3EThe%20MCSPTR2AK396%20kit%20is%20specifically%20intended%20for%20motor-control%20application%20development%20on%20the%20S32K396%2C%20and%20NXP%20provides%20the%20reference%20software%20as%20ANSI%20C%20source%20code%20for%20non-AUTOSAR%20applications%2C%20making%20it%20suitable%20for%20developing%20and%20replacing%20parts%20of%20the%20control%20algorithm%20with%20your%20own%20custom%20C%20code.%3C%2FP%3E%0A%3CP%3ETypical%20software%20toolchain%3A%3C%2FP%3E%0A%3CP%3ES32%20Design%20Studio%20(S32DS)%20%E2%80%93%20IDE%2C%20compiler%2C%20debugger%3CBR%20%2F%3ERTD%20(Real-Time%20Drivers)%20%E2%80%93%20S32K3%20peripheral%20drivers%3CBR%20%2F%3ES32%20Configuration%20Tool%20(S32CT)%20%E2%80%93%20pin%2Fclock%2Fperipheral%20configuration%3CBR%20%2F%3EAMMCLib%20%E2%80%93%20motor-control%20algorithms%20library%3CBR%20%2F%3EFreeMASTER%20%E2%80%93%20runtime%20monitoring%20and%20debugging%3CBR%20%2F%3EMCAT%20%E2%80%93%20motor%20parameter%20identification%20and%20tuning%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%3C%2FLINGO-BODY%3E
