motor control hall sensor
1,904件の閲覧回数
michelet1
hi, i'm using motors that contain both hall sensor and encoder but in the motor control examples i found code that refers only to the encoder. I was wondering if there is any example, sdk etc .. in which there is some code that uses the hall sensor.
In this moment i am using RT1050EVKB and i find example mc_pmsm but not hall sensor.
Thanks in advance
1,896件の閲覧回数
CarlosGarabito
Hi, in MCUXpress we don't have examples, but you can check this board and download the software to compare with your project
