Stall problem
Stall problem
abderrahimjamao
Hello everyone,
I have a problem when I try to control my motor in sensored mode ( it works in sensorless mode without problem).
as soon as he enters the run state indicates a stall fault. what does it mean this error?
regards,
Alexis_A
Hello [email protected],
In the application code to enable the sensor mode, you need to change the #define HALL_SENSOR to 1 so the FTM2 is enabled. After this change still the motor stalls?
Best Regards.
Alexis Andalon
abderrahimjamao
Hi Alexis Andalon,
Yes, I already change the HALL_SENSOR to 1 but the motor stalls.
Abderrahim jamaoui
