Hello, all
I ask the question based on customer requirement
On the application note AN3943, there is an explanation to calculate parameters for a resolver with Mathlab (page 28).
With mathlab you can easily calculate paramter K1_scaled, K1_shift,K2scaled, K2_shift.
If you use ACLIB_AngleTrackObsvr from Aclib for 56800Ex, you have
K1_scaled, K1_shift,K2scaled, K2_shift and an extra parameter called A2_scaled, A2_shift.
Do you have a Mathlab method to calculate K1,K2, and A2 parameters. Regarding the A2 parameter definition (f16A2Scaled), pls refer to the 56800Ex_ACLIB.pdf
Thanks and best regards,
XiangJun Rong
