s32k3xx_dio_s32ct Information cache folder or artifacts were missing Error
mohit2904
Running S32K3_Examples s32k3xx_dio_s32ct but getting error while Generate code for this example model.
Please find attached build summary and below log details and please support.
### Starting build procedure for: s32k3xx_dio_s32ct
### Generating code and artifacts to 'Model specific' folder structure
### Generating code into build folder: C:\MATLABAddOns\Toolboxes\NXP_MBDToolbox_S32K3\S32K3_Examples\dio\s32k3xx_dio_s32ct\s32k3xx_dio_s32ct_ert_rtw
### Invoking Target Language Compiler on s32k3xx_dio_s32ct.rtw
### Using System Target File: C:\MATLAB\R2024b\rtw\c\ert\ert.tlc
### Loading TLC function libraries ........
### Generating TLC interface API for custom data .
### Initial pass through model to cache user defined code .
### Caching model source code ...........................................
### Writing header file s32k3xx_dio_s32ct_types.h
### Writing header file s32k3xx_dio_s32ct.h .
### Writing header file rtwtypes.h
### Writing source file s32k3xx_dio_s32ct.c
### Writing header file s32k3xx_dio_s32ct_private.h
### Writing source file s32k3xx_dio_s32ct_data.c
### Writing header file rtmodel.h .
### Writing source file ert_main.c
### TLC code generation complete (took 12.619s).
### Saving binary information cache.
### Using toolchain: S32DS GCC ### Creating 'C:\MATLABAddOns\Toolboxes\NXP_MBDToolbox_S32K3\S32K3_Examples\dio\s32k3xx_dio_s32ct\s32k3xx_dio_s32ct_ert_rtw\s32k3xx_dio_s32ct.mk' ... ### Building 's32k3xx_dio_s32ct': "C:\MATLAB\R2024b\bin\win64\gmake" -f s32k3xx_dio_s32ct.mk -j all C:\MATLABAddOns\Toolboxes\NXP_MBDToolbox_S32K3\S32K3_Examples\dio\s32k3xx_dio_s32ct\s32k3xx_dio_s32ct_ert_rtw>set PATH=C:\MATLABAddOns\Toolboxes\NXP_MBDToolbox_S32K3\tools\build_tools\gcc_v10.2\gcc-10.2-arm32-eabi\bin;C:\MATLAB\R2024b\bin\win64;C:\Users\hp\AppData\Local\Programs\Python\Python310\Scripts\;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\PuTTY\;C:\Users\hp\AppData\Local\Programs\Python\Python310\;C:\Program Files\Microsoft SQL Server\140\Tools\Binn\;C:\Program Files (x86)\Geehy\openocd-20240916\OpenOCD-20240916-0.12.0\bin;C:\Program Files (x86)\Geehy\xpack-windows-build-tools-4.3.0-1-win32-x64\xpack-windows-build-tools-4.3.0-1\bin;C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2021.10\bin;C:\Program Files\Git\cmd;C:\Program Files\dotnet\;C:\MATLAB\R2024b\bin;C:\Program Files\7-Zip;C:\Users\hp\.mcuxpressotools\dtc-1.6.1\tools\usr\bin;C:\Users\hp\.mcuxpressotools\gperf-3.0.1\bin;C:\Users\hp\.mcuxpressotools\wget-1.21.4;C:\Users\hp\.mcuxpressotools\ninja-1.12.1;C:\Users\hp\.mcuxpressotools\cmake-3.30.0-windows-x86_64\bin;C:\Program Files\Python\Python310\Scripts\;C:\Program Files (x86)\Vim\vim90;C:\Users\hp\AppData\Local\Programs\Microsoft VS Code\bin C:\MATLABAddOns\Toolboxes\NXP_MBDToolbox_S32K3\S32K3_Examples\dio\s32k3xx_dio_s32ct\s32k3xx_dio_s32ct_ert_rtw>cd . C:\MATLABAddOns\Toolboxes\NXP_MBDToolbox_S32K3\S32K3_Examples\dio\s32k3xx_dio_s32ct\s32k3xx_dio_s32ct_ert_rtw>if "all" == "" ("C:\MATLAB\R2024b\bin\win64\gmake" -f s32k3xx_dio_s32ct.mk -j all ) else ("C:\MATLAB\R2024b\bin\win64\gmake" -f s32k3xx_dio_s32ct.mk -j all ) "C:\MATLAB\R2024b\bin\win64\gmake": Interrupt/Exception caught (code = 0xc00000fd, addr = 0x41a0c5) C:\MATLABAddOns\Toolboxes\NXP_MBDToolbox_S32K3\S32K3_Examples\dio\s32k3xx_dio_s32ct\s32k3xx_dio_s32ct_ert_rtw>echo The make command returned an error of 255 The make command returned an error of 255 C:\MATLABAddOns\Toolboxes\NXP_MBDToolbox_S32K3\S32K3_Examples\dio\s32k3xx_dio_s32ct\s32k3xx_dio_s32ct_ert_rtw>exit /B 1
### Build procedure for s32k3xx_dio_s32ct aborted due to an error.
Build Summary
Top model targets: Model Build Reason Status Build Duration =============================================================================================================================================
s32k3xx_dio_s32ct Information cache folder or artifacts were missing. Failed to build.
Error(s) encountered while building "s32k3xx_dio_s32ct"
dragostoma
Hi, @mohit2904,
Could you please copy and paste the entire log text? That will make it easier to identify the problem. Moreover, feel free to include the model example as well, so we can take a look.
Dragos
%3CLINGO-SUB%20id%3D%22lingo-sub-2265207%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Es32k3xx_dio_s32ct%20%20Information%20cache%20folder%20or%20artifacts%20were%20missing%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265207%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3ERunning%26nbsp%3BS32K3_Examples%26nbsp%3Bs32k3xx_dio_s32ct%20but%20getting%20error%20while%26nbsp%3BGenerate%20code%20for%20this%20example%20model.%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3EPlease%20find%20attached%20build%20summary%20and%20below%20log%20details%20and%20please%20support.%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Starting%20build%20procedure%20for%3A%20s32k3xx_dio_s32ct%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Generating%20code%20and%20artifacts%20to%20'Model%20specific'%20folder%20structure%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Generating%20code%20into%20build%20folder%3A%20C%3A%5CMATLABAddOns%5CToolboxes%5CNXP_MBDToolbox_S32K3%5CS32K3_Examples%5Cdio%5Cs32k3xx_dio_s32ct%5Cs32k3xx_dio_s32ct_ert_rtw%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Invoking%20Target%20Language%20Compiler%20on%20s32k3xx_dio_s32ct.rtw%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Using%20System%20Target%20File%3A%20C%3A%5CMATLAB%5CR2024b%5Crtw%5Cc%5Cert%5Cert.tlc%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Loading%20TLC%20function%20libraries%20........%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Generating%20TLC%20interface%20API%20for%20custom%20data%20.%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Initial%20pass%20through%20model%20to%20cache%20user%20defined%20code%20.%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Caching%20model%20source%20code%20...........................................%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Writing%20header%20file%20s32k3xx_dio_s32ct_types.h%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Writing%20header%20file%20s32k3xx_dio_s32ct.h%20.%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Writing%20header%20file%20rtwtypes.h%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Writing%20source%20file%20s32k3xx_dio_s32ct.c%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Writing%20header%20file%20s32k3xx_dio_s32ct_private.h%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Writing%20source%20file%20s32k3xx_dio_s32ct_data.c%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Writing%20header%20file%20rtmodel.h%20.%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Writing%20source%20file%20ert_main.c%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20TLC%20code%20generation%20complete%20(took%2012.619s).%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Saving%20binary%20information%20cache.%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Using%20toolchain%3A%20S32DS%20GCC%20%23%23%23%20Creating%20'C%3A%5CMATLABAddOns%5CToolboxes%5CNXP_MBDToolbox_S32K3%5CS32K3_Examples%5Cdio%5Cs32k3xx_dio_s32ct%5Cs32k3xx_dio_s32ct_ert_rtw%5Cs32k3xx_dio_s32ct.mk'%20...%20%23%23%23%20Building%20's32k3xx_dio_s32ct'%3A%20%22C%3A%5CMATLAB%5CR2024b%5Cbin%5Cwin64%5Cgmake%22%20-f%20s32k3xx_dio_s32ct.mk%20-j%20all%20C%3A%5CMATLABAddOns%5CToolboxes%5CNXP_MBDToolbox_S32K3%5CS32K3_Examples%5Cdio%5Cs32k3xx_dio_s32ct%5Cs32k3xx_dio_s32ct_ert_rtw%26gt%3Bset%20PATH%3DC%3A%5CMATLABAddOns%5CToolboxes%5CNXP_MBDToolbox_S32K3%5Ctools%5Cbuild_tools%5Cgcc_v10.2%5Cgcc-10.2-arm32-eabi%5Cbin%3BC%3A%5CMATLAB%5CR2024b%5Cbin%5Cwin64%3BC%3A%5CUsers%5Chp%5CAppData%5CLocal%5CPrograms%5CPython%5CPython310%5CScripts%5C%3BC%3A%5CProgram%20Files%20(x86)%5CCommon%20Files%5COracle%5CJava%5Cjavapath%3BC%3A%5CWindows%5Csystem32%3BC%3A%5CWindows%3BC%3A%5CWindows%5CSystem32%5CWbem%3BC%3A%5CWindows%5CSystem32%5CWindowsPowerShell%5Cv1.0%5C%3BC%3A%5CWindows%5CSystem32%5COpenSSH%5C%3BC%3A%5CProgram%20Files%5CPuTTY%5C%3BC%3A%5CUsers%5Chp%5CAppData%5CLocal%5CPrograms%5CPython%5CPython310%5C%3BC%3A%5CProgram%20Files%5CMicrosoft%20SQL%20Server%5C140%5CTools%5CBinn%5C%3BC%3A%5CProgram%20Files%20(x86)%5CGeehy%5Copenocd-20240916%5COpenOCD-20240916-0.12.0%5Cbin%3BC%3A%5CProgram%20Files%20(x86)%5CGeehy%5Cxpack-windows-build-tools-4.3.0-1-win32-x64%5Cxpack-windows-build-tools-4.3.0-1%5Cbin%3BC%3A%5CProgram%20Files%20(x86)%5CGNU%20Arm%20Embedded%20Toolchain%5C10%202021.10%5Cbin%3BC%3A%5CProgram%20Files%5CGit%5Ccmd%3BC%3A%5CProgram%20Files%5Cdotnet%5C%3BC%3A%5CMATLAB%5CR2024b%5Cbin%3BC%3A%5CProgram%20Files%5C7-Zip%3BC%3A%5CUsers%5Chp%5C.mcuxpressotools%5Cdtc-1.6.1%5Ctools%5Cusr%5Cbin%3BC%3A%5CUsers%5Chp%5C.mcuxpressotools%5Cgperf-3.0.1%5Cbin%3BC%3A%5CUsers%5Chp%5C.mcuxpressotools%5Cwget-1.21.4%3BC%3A%5CUsers%5Chp%5C.mcuxpressotools%5Cninja-1.12.1%3BC%3A%5CUsers%5Chp%5C.mcuxpressotools%5Ccmake-3.30.0-windows-x86_64%5Cbin%3BC%3A%5CProgram%20Files%5CPython%5CPython310%5CScripts%5C%3BC%3A%5CProgram%20Files%20(x86)%5CVim%5Cvim90%3BC%3A%5CUsers%5Chp%5CAppData%5CLocal%5CPrograms%5CMicrosoft%20VS%20Code%5Cbin%20C%3A%5CMATLABAddOns%5CToolboxes%5CNXP_MBDToolbox_S32K3%5CS32K3_Examples%5Cdio%5Cs32k3xx_dio_s32ct%5Cs32k3xx_dio_s32ct_ert_rtw%26gt%3Bcd%20.%20C%3A%5CMATLABAddOns%5CToolboxes%5CNXP_MBDToolbox_S32K3%5CS32K3_Examples%5Cdio%5Cs32k3xx_dio_s32ct%5Cs32k3xx_dio_s32ct_ert_rtw%26gt%3Bif%20%22all%22%20%3D%3D%20%22%22%20(%22C%3A%5CMATLAB%5CR2024b%5Cbin%5Cwin64%5Cgmake%22%20-f%20s32k3xx_dio_s32ct.mk%20-j%20all%20)%20else%20(%22C%3A%5CMATLAB%5CR2024b%5Cbin%5Cwin64%5Cgmake%22%20-f%20s32k3xx_dio_s32ct.mk%20-j%20all%20)%20%22C%3A%5CMATLAB%5CR2024b%5Cbin%5Cwin64%5Cgmake%22%3A%20Interrupt%2FException%20caught%20(code%20%3D%200xc00000fd%2C%20addr%20%3D%200x41a0c5)%20%3CSTRONG%3EC%3A%5CMATLABAddOns%5CToolboxes%5CNXP_MBDToolbox_S32K3%5CS32K3_Examples%5Cdio%5Cs32k3xx_dio_s32ct%5Cs32k3xx_dio_s32ct_ert_rtw%26gt%3Becho%20The%20make%20command%20returned%20an%20error%20of%20255%20The%20make%20command%20returned%20an%20error%20of%20255%3C%2FSTRONG%3E%20C%3A%5CMATLABAddOns%5CToolboxes%5CNXP_MBDToolbox_S32K3%5CS32K3_Examples%5Cdio%5Cs32k3xx_dio_s32ct%5Cs32k3xx_dio_s32ct_ert_rtw%26gt%3Bexit%20%2FB%201%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%23%23%23%20Build%20procedure%20for%20s32k3xx_dio_s32ct%20aborted%20due%20to%20an%20error.%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3EBuild%20Summary%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3ETop%20model%20targets%3A%20Model%20Build%20Reason%20Status%20Build%20Duration%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3Es32k3xx_dio_s32ct%20Information%20cache%20folder%20or%20artifacts%20were%20missing.%20Failed%20to%20build.%3C%2FSTRONG%3E%26nbsp%3B%3C%2FSPAN%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EError(s)%20encountered%20while%20building%20%22%3CA%20href%3D%22matlab%3Adas_dv_hyperlink('DAS'%2C'mdl'%2C's32k3xx_dio_s32ct')%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Es32k3xx_dio_s32ct%3C%2FA%3E%22%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2265821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k3xx_dio_s32ct%20%20Information%20cache%20folder%20or%20artifacts%20were%20missing%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F199298%22%20target%3D%22_blank%22%3E%40mohit2904%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20copy%20and%20paste%20the%20entire%20log%20text%3F%20That%20will%20make%20it%20easier%20to%20identify%20the%20problem.%20Moreover%2C%20feel%20free%20to%20include%20the%20model%20example%20as%20well%2C%20so%20we%20can%20take%20a%20look.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EDragos%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
