s-function builder
s-function builder
2,498件の閲覧回数
saurabhkulkarni123
I have LED blinking code of s32k148, now I want to build custom block for that I have to port this code in S-function builder block and generate TLC file for same. I want know about procedure for this and also want to know about which files are required for building in s-function builder.
2,495件の閲覧回数
Martha09
To build a custom S-function block in Simulink's S-function Builder, you can Prepare the code, Creation an S-function project, Define S-function parameters, Implement S-functions methods, Configure S-function builder, Build the S-function, test and Deploy.
2,487件の閲覧回数
saurabhkulkarni123
I have code where Pin are assign to led, but in s-function builder how can I declare pin.
