imxrt1170 simulink toolbox testing
1,134 次查看
heyam
I’m using the NXP Model-Based Design Toolbox for i.MX RT Crossover MCUs – version 1.3.0 in Simulink 2021a. I’m trying to test the UART blocks in eDMA mode. The sending block works successfully, but the receiving block executes only once and then halts. Each time the board is reset, the receive block executes once, I need to receive data every sample time can you solve this issue
1,117 次查看
EdwinHz
Hi @heyam,
Your post has been moved to the MBDT community so you can receive appropriate support on your topic.
