Hello uit,
Here on the Model-Based Design community we handle questions regarding our toolbox or other MATLAB/Simulink related questions. Your question is best suited for the S32DS community (here), so my advice is to ask it there (as I can not move it myself).
What I can tell you is that IDs from 0 to 59 are used for data frames, while IDs 60 and 61 are used to carry diagnostic data, so this might be the reason why S32DS only lets you select from 0 to 59. But again, you'll probably get a more detailed answer on the S32DS community.
Hope this helps,
Razvan.
