how to build the program that generated by MBD toolbox in the S32DS ???
2,680件の閲覧回数
642142357
build the program that generated by MBD toolbox in the S32DS,show errors as follow,how to resolve it???thks
constantinrazvan.chivu‌khumphriMandardhavalRHinnenjimtrudeau
ラベル(2)
2,576件の閲覧回数
paulvlase
Hi [email protected]‌,
The S32 Design Studio ProjectInfo.xml importer doesn't recognize the -lm flag from the linker options and thus doesn't add the C standard math library to the imported S32 Design Studio project.
To fix those build errors you have to add the math library by yourself by following the next steps:
1. Right click on your S32 Design Studio project and open the project's Properties.
2. Go to C/C++ Build > Settings > Standard S32DS C Linker > Libraries.
3. Press the Add button pointed by the yellow arrow to add the standard C math library, called m. Press the OK button at the end to save your changes.
4, Build the project.
Paul
2,577件の閲覧回数
paulvlase
Paul
