gpio_s32k14_output block (mask) does not have a parameter named 'port'
2,101件の閲覧回数
1586526941
gpio_s32k14_output block (mask) does not have a parameter named 'port',How to solve this problem?
2,026件の閲覧回数
constantinrazva
Hello 1586526941@qq.com‌,
Can you provide the example you are trying to build?
A few more questions to get a better understanding of the context - do you have the correct path set ? Do you have multiple toolboxes installed ? Maybe more versions of the S32K toolbox?
Can you send me the output of the following MATLAB command:
ver
Kind regards,
Razvan.
2,026件の閲覧回数
1586526941
hi
    the toolbox version is MBDToolbox S32K1xx_2018.R1_20180723.mltbx,when the Dightal_Output is existing,to load the Write_Register, this problem will arise.
