devkit MPC5744P communication test
4,725 次查看
henryex2009
 Hi everyone,
 I used MPC5744P to test UART . I successfully download the "Hello word" example to the DEVKIT 5744P
through this MBT tool(Version 3.2),but the Tera Term show nothing. Please tell me how to solve this problem.
BTW, the CAN commuication example also has same problem.The model is download into DEVKIT 5744P,but I can't see the CAN RX/TX( by INCA).
4,639 次查看
hbhnhbnhj1
Hi @henryex2009,
You can change the serial port to 0 as shown in figure below, it should work.
标记 (3)
4,640 次查看
hbhnhbnhj1
Hi @henryex2009,
标记 (3)
4,599 次查看
henryex2009
Hi,hbhnhbnhj1,
It works,thank you for your assistance
4,592 次查看
mariuslucianand
Hello @henryex2009
Please have a look at the Schematics of the EVBs before developing your application, to make sure that the right pins are selected inside the blocks, alongside the right UART instances.
https://www.nxp.com/design/development-boards/automotive-development-platforms/mpc57xx-mcu-platforms...
Hope this helps,
Marius
