build error
build error
1,990件の閲覧回数
satvenmechatron
1) I couldnot see NXP s32k144 in target board option in hardware implementation in configuration parameters.
2) what should i choose target board for external mode simulation.
2) though I have choosen determine target board by code gen target file option and getting build error.
please do help.
1,979件の閲覧回数
mariuslucianand
Hello @satvenmechatron
Indeed, for the MBDT for S32K we are using a different approach. To configure a model for an S32k1xx board, you have to add an MBD_S32K1xx_Config_Information block like the one attached here. I strongly suggest to start from one of our examples.
For the external mode, again we have an example in our toolbox. We had a question recently where we explained how to run an external mode example. Please have a look here. https://community.nxp.com/t5/NXP-Model-Based-Design-Tools/Unable-to-Deploy-and-Start-External-Mode-E...
Have you used one of our examples? Also, I've seen in your attached screenshot that your Add-Ons location contains some spaces, and Matlab does not like spaces in path.image.pngimage.png
You might consider changing the location of the add-ons in smth like C:/AddOns. To do that, you can go to Preferences -> Add-Ons and change that path.
Marius
