Why the MPC5744P CAN can not Transmit the data out ?
2,221 次查看
edenli
Contributor V
Hi Guys,
I use the MPC5744P CAN block build the module,but there isn't any data being sent out,
i check the reason ,and i try the method by CAN Configuration issue on MPC5744P ,but still can not solve it
The CAN Engine Clock Soure is 40MHz by oscillator.
The attachment is my modle.
Original Attachment has been moved to: can_model_pnt.mdl.zip
1,921 次查看
Daniel_Popa
Hi edenli
What type of board are you using? The big one ( Development board) or the small one ( credit card format - Dev kit ) ?
1,921 次查看
edenli
Contributor V
Hi Daniel,
My board is MPC57XXXMB and MPC5744P-257DS.
1,921 次查看
Daniel_Popa
I can't check right now - but i think you need to use the v1.1.0 (https://nxp.flexnetoperations.com/control/frse/download?agree=Accept&element=6107521 ) of the toolbox for MPC574xP. The 2.0.0 supports only the newer parts. That might explain why is not working.
