Want to implement a field-oriented Permanent Magnet Synchronous Motor (PMSM) control?
1,907件の閲覧回数
yosoytono
Fresh Out Contributor
Performing mechanical movements for reliable applications demands suitable control strategies of the electric motors; those motor control techniques are complex and require knowledge of both controlled system and control structure parameters. We are offering a Design and Develop Motor Control Applications with NXP MagniV MCUs using Model-Based Design Toolbox free webinar so you can learn how to design and test a Permanent Magnet Synchronous Motor (PMSM) Control algorithm for initial development stages.
dumitru-daniel.popa‌ will use a hardware and software simulation environment for NXP Model-Based Design Toolbox (MBDT) and show you how to increase its performance using dedicated NXP libraries for Motor Control (AMMCLIB) by generating automatic C-code for an NXP S12 MagniV MCU; finally, he will guide you through the implementation and motor control application testing using dedicated NXP Motor Control Kit.
DATE: Tuesday, April 24, 2018
TIME: 11:00 AM EDT
Join to learn more and start implementing your PMSM control algorithm!
0 返答(返信)
