Using MCU-Link with iMXRT1062xxx
2,571 次查看
Sam_ECU
How should I configure Simulink to flash to a custom board using MCU-Link?
I can flash to the board using MCUXpresso. Report attached.
In Simulink I used the same .cfx file and I directed the XML to the same folder as the example in MCUXpresso.
What do I need to do differently in Simulink? Report attached.
Sam
2,545 次查看
Sam_ECU
* Attached the xml and cfg
