The error of MATLAB s32v234 evaluation board simulation
13,708件の閲覧回数
751301185
When I use matlab s32v234 evaluation board to simulate face detection, the following problems occur:
make[1]: Leaving directory '/g/Matlab2018file/codegen/exe/face_detection/build-v234ce-gnu-linux-o'
make: *** [/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/build/nbuild/platforms/coordinator.mk:57: allsub] Error 2
Who can help me, thank you
The log information is as follows:
run_application
FFmpeg library already installed
### Using toolchain: S32DS Vision GCC
### Creating 'G:\Matlab2018file\codegen\exe\face_detection\face_detection_rtw.mk' ...
Warning: coder.wref() is treated as coder.ref() when applied on a variable-sized array or a structure with variable-sized fields.
Warning in ==> UMat_int32 Line: 97 Column: 75
Code generation successful (with warnings): View report
警告: 目录已存在。
> In nxpvt_build
In nxpvt_make
In nxpvt_codegen
In nxpvt_runner/Run (line 63)
In run_application (line 7)
G:\Matlab2018file\codegen\exe\face_detection>SET PATH=G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;G:\Matlab2018a\bin\win64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\dotnet\;G:\OpenCV\opencv\build\x64\vc14\bin;C:\WINDOWS\System32\OpenSSH\;G:\vscode\Microsoft VS Code\bin;G:\OpenCV\mybuild\install\bin;G:\Cmake\bin;G:\ffmpeg\bin;G:\OpenCV\mybuild\3rdparty\ffmpeg;G:\OpenCV\opencv\sources\3rdparty\ffmpeg;G:\Python;C:\Users\rayle\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\bin\x64;G:\Matlab2018a\runtime\win64;G:\Matlab2018a\bin;G:\Matlab\runtime\win64;G:\Matlab\bin;G:\Matlab\polyspace\bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;G:\MinGW\bin;E:\PuTTY\;E:\Git\cmd;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;E:\AOMEI Backupper;C:\Users\rayle\AppData\Local\Microsoft\WindowsApps;
G:\Matlab2018file\codegen\exe\face_detection>SET PATH=G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv8-eabi/i686-mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;G:\Matlab2018a\bin\win64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\dotnet\;G:\OpenCV\opencv\build\x64\vc14\bin;C:\WINDOWS\System32\OpenSSH\;G:\vscode\Microsoft VS Code\bin;G:\OpenCV\mybuild\install\bin;G:\Cmake\bin;G:\ffmpeg\bin;G:\OpenCV\mybuild\3rdparty\ffmpeg;G:\OpenCV\opencv\sources\3rdparty\ffmpeg;G:\Python;C:\Users\rayle\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\bin\x64;G:\Matlab2018a\runtime\win64;G:\Matlab2018a\bin;G:\Matlab\runtime\win64;G:\Matlab\bin;G:\Matlab\polyspace\bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;G:\MinGW\bin;E:\PuTTY\;E:\Git\cmd;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;E:\AOMEI Backupper;C:\Users\rayle\AppData\Local\Microsoft\WindowsApps;
G:\Matlab2018file\codegen\exe\face_detection>SET PATH=G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Xarmv8-linux/i686-mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv8-eabi/i686-mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;G:\Matlab2018a\bin\win64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\dotnet\;G:\OpenCV\opencv\build\x64\vc14\bin;C:\WINDOWS\System32\OpenSSH\;G:\vscode\Microsoft VS Code\bin;G:\OpenCV\mybuild\install\bin;G:\Cmake\bin;G:\ffmpeg\bin;G:\OpenCV\mybuild\3rdparty\ffmpeg;G:\OpenCV\opencv\sources\3rdparty\ffmpeg;G:\Python;C:\Users\rayle\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\bin\x64;G:\Matlab2018a\runtime\win64;G:\Matlab2018a\bin;G:\Matlab\runtime\win64;G:\Matlab\bin;G:\Matlab\polyspace\bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;G:\MinGW\bin;E:\PuTTY\;E:\Git\cmd;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;E:\AOMEI Backupper;C:\Users\rayle\AppData\Local\Microsoft\WindowsApps;
G:\Matlab2018file\codegen\exe\face_detection>SET PATH=G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../msys32/mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../msys32/usr/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../msys32/mingw64/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Xarmv8-linux/i686-mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv8-eabi/i686-mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;G:\Matlab2018a\bin\win64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\dotnet\;G:\OpenCV\opencv\build\x64\vc14\bin;C:\WINDOWS\System32\OpenSSH\;G:\vscode\Microsoft VS Code\bin;G:\OpenCV\mybuild\install\bin;G:\Cmake\bin;G:\ffmpeg\bin;G:\OpenCV\mybuild\3rdparty\ffmpeg;G:\OpenCV\opencv\sources\3rdparty\ffmpeg;G:\Python;C:\Users\rayle\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\bin\x64;G:\Matlab2018a\runtime\win64;G:\Matlab2018a\bin;G:\Matlab\runtime\win64;G:\Matlab\bin;G:\Matlab\polyspace\bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;G:\MinGW\bin;E:\PuTTY\;E:\Git\cmd;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;E:\AOMEI Backupper;C:\Users\rayle\AppData\Local\Microsoft\WindowsApps;
Current SDK ROOT is /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk
make[1]: Entering directory '/g/Matlab2018file/codegen/exe/face_detection/build-v234ce-gnu-linux-o'
/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/build/nbuild/sub.mk:73: sub.mk: SUB_DIR /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_base/apexcv_common/include is missing
/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/build/nbuild/sub.mk:73: sub.mk: SUB_DIR G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234\(2\)/code//internals/include/s32v is missing
/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/build/nbuild/sub.mk:73: sub.mk: SUB_DIR G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234\(2\)/code//internals/libs/object_detection/include is missing
/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/build/nbuild/sub.mk:73: SUB_MAKE /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_base/apexcv_common/build-v234ce-gnu-linux-o/ is missing
/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/build/nbuild/sub.mk:73: SUB_MAKE G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234\(2\)/code//internals/libs/object_detection/build-v234ce-gnu-linux-o/ is missing
/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/build/nbuild/sub.mk:73: SUB_MAKE /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_pro/resize/apu-nxp/build-v234ce-gnu-linux-o/ is missing
/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/build/nbuild/sub.mk:73: *** You can find the missing directory/directories here: /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_base/apexcv_common/include G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234\(2\)/code//internals/include/s32v G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234\(2\)/code//internals/libs/object_detection/include /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_base/apexcv_common/build-v234ce-gnu-linux-o/ G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234\(2\)/code//internals/libs/object_detection/build-v234ce-gnu-linux-o/ /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_pro/resize/apu-nxp/build-v234ce-gnu-linux-o/ [/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_base/apexcv_common/include G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/(2/)/code/internals/include/s32v G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/(2/)/code/internals/libs/object_detection/include /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_base/apexcv_common/build-v234ce-gnu-linux-o G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/(2/)/code/internals/libs/object_detection/build-v234ce-gnu-linux-o /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_pro/resize/apu-nxp/build-v234ce-gnu-linux-o]. Stop.
警告: Cannot deploy on target. Compilation failed..
> In nxpvt_codegen
>> run_application
13,249件の閲覧回数
iulianbulancea
Hi [email protected]‌,
It looks like you have the toolbox installed multiple times. Please remove the highlighted toolboxes from the image below ,by uninstalling them or just by deleting them, and install the toolbox again. You can not have more than one instance of the toolbox.
Kind regards,
Iulian Bulancea
11 返答(返信)
13,250件の閲覧回数
iulianbulancea
Kind regards,
Iulian Bulancea
13,245件の閲覧回数
751301185
Hi,Iulian Bulancea
As you said,uninstalling them or just by deleting them, and install the toolbox again,Still so.
>> run_application
[1] FPS: 1, Faces detected: 3,
>> run_application
### Creating 'C:\Users\rayle\Documents\MATLAB\codegen\exe\face_detection\face_detection_rtw.mk' ...
C:\Users\rayle\Documents\MATLAB\codegen\exe\face_detection>SET PATH=G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;G:\Matlab2018a\bin\win64;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\lib\oal;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\lib\opencv;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\target;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\dotnet\;G:\OpenCV\opencv\build\x64\vc14\bin;C:\WINDOWS\System32\OpenSSH\;G:\vscode\Microsoft VS Code\bin;G:\OpenCV\mybuild\install\bin;G:\Cmake\bin;G:\ffmpeg\bin;G:\OpenCV\mybuild\3rdparty\ffmpeg;G:\OpenCV\opencv\sources\3rdparty\ffmpeg;G:\Python;C:\Users\rayle\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\bin\x64;G:\Matlab2018a\runtime\win64;G:\Matlab2018a\bin;G:\Matlab\runtime\win64;G:\Matlab\bin;G:\Matlab\polyspace\bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;G:\MinGW\bin;E:\PuTTY\;E:\Git\cmd;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;E:\AOMEI Backupper;C:\Users\rayle\AppData\Local\Microsoft\WindowsApps;
C:\Users\rayle\Documents\MATLAB\codegen\exe\face_detection>SET PATH=G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv8-eabi/i686-mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;G:\Matlab2018a\bin\win64;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\lib\oal;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\lib\opencv;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\target;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\dotnet\;G:\OpenCV\opencv\build\x64\vc14\bin;C:\WINDOWS\System32\OpenSSH\;G:\vscode\Microsoft VS Code\bin;G:\OpenCV\mybuild\install\bin;G:\Cmake\bin;G:\ffmpeg\bin;G:\OpenCV\mybuild\3rdparty\ffmpeg;G:\OpenCV\opencv\sources\3rdparty\ffmpeg;G:\Python;C:\Users\rayle\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\bin\x64;G:\Matlab2018a\runtime\win64;G:\Matlab2018a\bin;G:\Matlab\runtime\win64;G:\Matlab\bin;G:\Matlab\polyspace\bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;G:\MinGW\bin;E:\PuTTY\;E:\Git\cmd;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;E:\AOMEI Backupper;C:\Users\rayle\AppData\Local\Microsoft\WindowsApps;
C:\Users\rayle\Documents\MATLAB\codegen\exe\face_detection>SET PATH=G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Xarmv8-linux/i686-mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv8-eabi/i686-mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;G:\Matlab2018a\bin\win64;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\lib\oal;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\lib\opencv;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\target;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\dotnet\;G:\OpenCV\opencv\build\x64\vc14\bin;C:\WINDOWS\System32\OpenSSH\;G:\vscode\Microsoft VS Code\bin;G:\OpenCV\mybuild\install\bin;G:\Cmake\bin;G:\ffmpeg\bin;G:\OpenCV\mybuild\3rdparty\ffmpeg;G:\OpenCV\opencv\sources\3rdparty\ffmpeg;G:\Python;C:\Users\rayle\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\bin\x64;G:\Matlab2018a\runtime\win64;G:\Matlab2018a\bin;G:\Matlab\runtime\win64;G:\Matlab\bin;G:\Matlab\polyspace\bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;G:\MinGW\bin;E:\PuTTY\;E:\Git\cmd;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;E:\AOMEI Backupper;C:\Users\rayle\AppData\Local\Microsoft\WindowsApps;
C:\Users\rayle\Documents\MATLAB\codegen\exe\face_detection>SET PATH=G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../msys32/mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../msys32/usr/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../msys32/mingw64/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Xarmv8-linux/i686-mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv8-eabi/i686-mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;G:\Matlab2018a\bin\win64;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\lib\oal;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\lib\opencv;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\target;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\dotnet\;G:\OpenCV\opencv\build\x64\vc14\bin;C:\WINDOWS\System32\OpenSSH\;G:\vscode\Microsoft VS Code\bin;G:\OpenCV\mybuild\install\bin;G:\Cmake\bin;G:\ffmpeg\bin;G:\OpenCV\mybuild\3rdparty\ffmpeg;G:\OpenCV\opencv\sources\3rdparty\ffmpeg;G:\Python;C:\Users\rayle\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\bin\x64;G:\Matlab2018a\runtime\win64;G:\Matlab2018a\bin;G:\Matlab\runtime\win64;G:\Matlab\bin;G:\Matlab\polyspace\bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;G:\MinGW\bin;E:\PuTTY\;E:\Git\cmd;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;E:\AOMEI Backupper;C:\Users\rayle\AppData\Local\Microsoft\WindowsApps;
make[1]: Entering directory '/c/Users/rayle/Documents/MATLAB/codegen/exe/face_detection/build-v234ce-gnu-linux-o'
/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/build/nbuild/sub.mk:73: *** You can find the missing directory/directories here: /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_base/apexcv_common/include /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_base/apexcv_common/build-v234ce-gnu-linux-o/ /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_pro/resize/apu-nxp/build-v234ce-gnu-linux-o/ [/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_base/apexcv_common/include /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_base/apexcv_common/build-v234ce-gnu-linux-o /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_pro/resize/apu-nxp/build-v234ce-gnu-linux-o]. Stop.
make[1]: Leaving directory '/c/Users/rayle/Documents/MATLAB/codegen/exe/face_detection/build-v234ce-gnu-linux-o'
> In nxpvt_codegen
13,249件の閲覧回数
iulianbulancea
You must install Vision SDK version 1.4.0 and update the environmental variable S32V234_SDK_ROOT. You can follow  the steps from this tutorial AI and Machine Learning Course #1: Hardware and Software Setup. You should find the old releases on the Previous tab.
Let me know if you have any issues.
Kind regards,
Iulian Bulancea
13,251件の閲覧回数
751301185
Hi,Iulian Bulancea
I updated the Vision SDK version 1.4.0, I'm glad that the compilation passed, thank you very much, but there are the following problems, all the files exist, what's the problem
>> nxpvt_codegen('face_detection', config);
警告: 目录已存在。
> In nxpvt_build
In nxpvt_make
In nxpvt_codegen
C:\Users\rayle\Documents\MATLAB\codegen\exe\face_detection>SET PATH=G:/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;G:\Matlab2018a\bin\win64;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\lib\oal;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\lib\opencv;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\target;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\dotnet\;G:\OpenCV\opencv\build\x64\vc14\bin;C:\WINDOWS\System32\OpenSSH\;G:\vscode\Microsoft VS Code\bin;G:\OpenCV\mybuild\install\bin;G:\Cmake\bin;G:\ffmpeg\bin;G:\OpenCV\mybuild\3rdparty\ffmpeg;G:\OpenCV\opencv\sources\3rdparty\ffmpeg;G:\Python;C:\Users\rayle\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\bin\x64;G:\Matlab2018a\runtime\win64;G:\Matlab2018a\bin;G:\Matlab\runtime\win64;G:\Matlab\bin;G:\Matlab\polyspace\bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;G:\MinGW\bin;E:\PuTTY\;E:\Git\cmd;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;E:\AOMEI Backupper;C:\Users\rayle\AppData\Local\Microsoft\WindowsApps;
C:\Users\rayle\Documents\MATLAB\codegen\exe\face_detection>SET PATH=G:/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Xarmv8-linux/i686-mingw32/bin;G:/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;G:\Matlab2018a\bin\win64;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\lib\oal;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\lib\opencv;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\target;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\dotnet\;G:\OpenCV\opencv\build\x64\vc14\bin;C:\WINDOWS\System32\OpenSSH\;G:\vscode\Microsoft VS Code\bin;G:\OpenCV\mybuild\install\bin;G:\Cmake\bin;G:\ffmpeg\bin;G:\OpenCV\mybuild\3rdparty\ffmpeg;G:\OpenCV\opencv\sources\3rdparty\ffmpeg;G:\Python;C:\Users\rayle\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\bin\x64;G:\Matlab2018a\runtime\win64;G:\Matlab2018a\bin;G:\Matlab\runtime\win64;G:\Matlab\bin;G:\Matlab\polyspace\bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;G:\MinGW\bin;E:\PuTTY\;E:\Git\cmd;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;E:\AOMEI Backupper;C:\Users\rayle\AppData\Local\Microsoft\WindowsApps;
C:\Users\rayle\Documents\MATLAB\codegen\exe\face_detection>SET PATH=G:/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/../msys32/mingw32/bin;G:/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/../msys32/usr/bin;G:/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/../msys32/mingw64/bin;G:/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Xarmv8-linux/i686-mingw32/bin;G:/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;G:\Matlab2018a\bin\win64;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\lib\oal;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\lib\opencv;C:\Users\rayle\Documents\MATLAB\Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\code\internals\target;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\dotnet\;G:\OpenCV\opencv\build\x64\vc14\bin;C:\WINDOWS\System32\OpenSSH\;G:\vscode\Microsoft VS Code\bin;G:\OpenCV\mybuild\install\bin;G:\Cmake\bin;G:\ffmpeg\bin;G:\OpenCV\mybuild\3rdparty\ffmpeg;G:\OpenCV\opencv\sources\3rdparty\ffmpeg;G:\Python;C:\Users\rayle\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\bin\x64;G:\Matlab2018a\runtime\win64;G:\Matlab2018a\bin;G:\Matlab\runtime\win64;G:\Matlab\bin;G:\Matlab\polyspace\bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;G:\MinGW\bin;E:\PuTTY\;E:\Git\cmd;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;E:\AOMEI Backupper;C:\Users\rayle\AppData\Local\Microsoft\WindowsApps;
Current SDK ROOT is /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk
You use pre-built vsdk system libraries. You need to set PRE_BUILT_SYSTEM_LIBS=0 if you change the vsdk source code.
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apex/acf/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apex/acf/build-v234ce-gnu-linux-o'
make[3]: Nothing to be done for 'all'.
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apex/acf/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apex/acf/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apex/drivers/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apex/drivers/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apex/drivers/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apex/drivers/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apex/icp/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apex/icp/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apex/icp/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apex/icp/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_base/apexcv_common/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_base/apexcv_common/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_base/apexcv_common/build-v234ce-gnu-linux-o'
make[5]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_base/apexcv_common/build-v234ce-gnu-linux-o'
make[5]: Nothing to be done for 'all'.
make[5]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_base/apexcv_common/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_base/apexcv_common/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_base/apexcv_common/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_base/apexcv_common/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/common/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/common/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/common/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/common/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/communications/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/communications/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/communications/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/communications/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/log/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/log/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/log/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/log/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/sumat/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/sumat/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/sumat/build-v234ce-gnu-linux-o'
make[5]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/sumat/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/sumat/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/sumat/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/sumat/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/sumat/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[5]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[5]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[5]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[4]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[4]: Entering directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/kernels/apu/object_detection/build-apu-nxp-sa-d'
make[5]: Entering directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/kernels/apu/object_detection/build-apu-nxp-sa-d'
make[5]: Leaving directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/kernels/apu/object_detection/build-apu-nxp-sa-d'
make[4]: Leaving directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/kernels/apu/object_detection/build-apu-nxp-sa-d'
make[4]: Entering directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/graphs/build-apu-nxp-sa-d'
make[5]: Nothing to be done for 'apu_graphs'.
make[5]: Leaving directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/graphs/build-apu-nxp-sa-d'
make[5]: Nothing to be done for 'apu_graphs_link'.
make[4]: Leaving directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[7]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[7]: Nothing to be done for 'all'.
make[7]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[6]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[6]: Entering directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/kernels/apu/object_detection/build-apu-nxp-sa-d'
make[7]: Entering directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/kernels/apu/object_detection/build-apu-nxp-sa-d'
make[7]: Leaving directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/kernels/apu/object_detection/build-apu-nxp-sa-d'
make[6]: Leaving directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/kernels/apu/object_detection/build-apu-nxp-sa-d'
make[6]: Entering directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/graphs/build-apu-nxp-sa-d'
make[7]: Nothing to be done for 'apu_graphs'.
make[7]: Leaving directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/graphs/build-apu-nxp-sa-d'
make[7]: Nothing to be done for 'apu_graphs_link'.
make[6]: Leaving directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/c/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code/internals/libs/object_detection/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/isp/graphs/mipi_simple/dynamic_mipi_simple/build-v234ce-gnu-linux-o'
make[-]: skipping directory /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/isp/firmware/build-v234ce-gnu-linux-o
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/isp/graphs/mipi_simple/dynamic_mipi_simple/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/isp/graphs/mipi_simple/dynamic_mipi_simple/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/isp/graphs/mipi_simple/dynamic_mipi_simple/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/apu-nxp/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[5]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[5]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[4]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[4]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[5]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[4]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/apu-nxp/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/apu-nxp/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[7]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[7]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[6]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[6]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[7]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[6]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/apu-nxp/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/apu-nxp/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/apu-nxp/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/apu-nxp/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/apu-nxp/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/io/frame_io/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/io/frame_io/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/io/frame_io/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/io/frame_io/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/io/sdi/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/io/sdi/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/io/sdi/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/io/sdi/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/cam_generic/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/cam_generic/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/cam_generic/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/cam_generic/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/csi/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/csi/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/csi/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/csi/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/fdma/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/fdma/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/fdma/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/fdma/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/h264dec/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/h264dec/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/h264dec/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/h264dec/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/h264enc/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/h264enc/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/h264enc/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/h264enc/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/jpegdec/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/jpegdec/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/jpegdec/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/jpegdec/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/sequencer/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/sequencer/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/sequencer/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/sequencer/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/viu/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/viu/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/viu/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/viu/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/c/Users/rayle/Documents/MATLAB/codegen/exe/face_detection/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/c/Users/rayle/Documents/MATLAB/codegen/exe/face_detection/build-v234ce-gnu-linux-o'
.C0_headdep.mk: updating rtGetInf-cpp.C0.d
.C0_headdep.mk: updating rtGetNaN-cpp.C0.d
.C0_headdep.mk: updating rt_nonfinite-cpp.C0.d
.C0_headdep.mk: updating face_detection_emxutil-cpp.C0.d
.C0_headdep.mk: updating main-cpp.C0.d
.C0_headdep.mk: updating FilteredObject-cpp.C0.d
.C0_headdep.mk: updating filter_objects-cpp.C0.d
.C0_headdep.mk: updating face_detection-cpp.C0.d
.C0_headdep.mk: updating face_detection_terminate-cpp.C0.d
.C0_headdep.mk: updating face_detection_initialize-cpp.C0.d
.C0_headdep.mk: updating face_detection_rtwutil-cpp.C0.d
.C0_headdep.mk: updating nxpvt_videoreader_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_videoreader-cpp.C0.d
.C0_headdep.mk: updating nxpvt_videoinput_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_videoinput-cpp.C0.d
.C0_headdep.mk: updating nxpvt_utils-cpp.C0.d
.C0_headdep.mk: updating nxpvt_opencv_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_imshow_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_imread_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_resize_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_KalmanFilter_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_CascadeObjectDetector_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_CascadeObjectDetector-cpp.C0.d
.C0_headdep.mk: updating camera_input-cpp.C0.d
.C0_headdep.mk: updating nxpvt_umat_w-cpp.C0.d
arm64/gnu/optimized CX nxpvt_umat_w-cpp.o
arm64/gnu/optimized CX camera_input-cpp.o
arm64/gnu/optimized CX nxpvt_CascadeObjectDetector-cpp.o
arm64/gnu/optimized CX nxpvt_CascadeObjectDetector_w-cpp.o
arm64/gnu/optimized CX nxpvt_KalmanFilter_w-cpp.o
arm64/gnu/optimized CX nxpvt_apexcv_resize_w-cpp.o
arm64/gnu/optimized CX nxpvt_imread_w-cpp.o
arm64/gnu/optimized CX nxpvt_imshow_w-cpp.o
arm64/gnu/optimized CX nxpvt_opencv_w-cpp.o
arm64/gnu/optimized CX nxpvt_utils-cpp.o
arm64/gnu/optimized CX nxpvt_videoinput-cpp.o
arm64/gnu/optimized CX nxpvt_videoinput_w-cpp.o
arm64/gnu/optimized CX nxpvt_videoreader-cpp.o
arm64/gnu/optimized CX nxpvt_videoreader_w-cpp.o
arm64/gnu/optimized CX face_detection_rtwutil-cpp.o
arm64/gnu/optimized CX face_detection_initialize-cpp.o
arm64/gnu/optimized CX face_detection_terminate-cpp.o
arm64/gnu/optimized CX face_detection-cpp.o
arm64/gnu/optimized CX filter_objects-cpp.o
arm64/gnu/optimized CX FilteredObject-cpp.o
arm64/gnu/optimized CX main-cpp.o
arm64/gnu/optimized CX face_detection_emxutil-cpp.o
arm64/gnu/optimized CX rt_nonfinite-cpp.o
arm64/gnu/optimized CX rtGetNaN-cpp.o
arm64/gnu/optimized CX rtGetInf-cpp.o
arm64/gnu/optimized LD face_detection.elf <= nxpvt_umat_w-cpp.o camera_input-cpp.o nxpvt_CascadeObjectDetector-cpp.o nxpvt_CascadeObjectDetector_w-cpp.o nxpvt_KalmanFilter_w-cpp.o nxpvt_apexcv_resize_w-cpp.o nxpvt_imread_w-cpp.o nxpvt_imshow_w-cpp.o nxpvt_opencv_w-cpp.o nxpvt_utils-cpp.o nxpvt_videoinput-cpp.o nxpvt_videoinput_w-cpp.o nxpvt_videoreader-cpp.o nxpvt_videoreader_w-cpp.o face_detection_rtwutil-cpp.o face_detection_initialize-cpp.o face_detection_terminate-cpp.o face_detection-cpp.o filter_objects-cpp.o FilteredObject-cpp.o main-cpp.o face_detection_emxutil-cpp.o rt_nonfinite-cpp.o rtGetNaN-cpp.o rtGetInf-cpp.o /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apex/acf/build-v234ce-gnu-linux-o/libacf.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apex/drivers/user/build-v234ce-gnu-linux-o/libapexdrv.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apex/icp/build-v234ce-gnu-linux-o/libicp.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_base/apexcv_common/build-v234ce-gnu-linux-o/apexcv_common.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/common/build-v234ce-gnu-linux-o/libcommon.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/communications/build-v234ce-gnu-linux-o/lib_communications.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/log/build-v234ce-gnu-linux-o/liblog.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/sumat/build-v234ce-gnu-linux-o/libsumat.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o/libumat.a C:/Users/rayle/Documents/MATLAB/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/code//internals/libs/object_detection/build-v234ce-gnu-linux-o/nxpvt_object_detection.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/isp/graphs/mipi_simple/dynamic_mipi_simple/build-v234ce-gnu-linux-o/libdynamic_mipi_simple.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/apexcv_pro/resize/apu-nxp/build-v234ce-gnu-linux-o/apexcv_pro_resize.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/io/frame_io/build-v234ce-gnu-linux-o/libframe_io.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/io/sdi/build-v234ce-gnu-linux-o/libsdi.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/cam_generic/user/build-v234ce-gnu-linux-o/libcamdrv.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/csi/user/build-v234ce-gnu-linux-o/libcsidrv.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/fdma/user/build-v234ce-gnu-linux-o/libfdmadrv.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/h264dec/user/build-v234ce-gnu-linux-o/libh264decdrv.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/h264enc/user/build-v234ce-gnu-linux-o/libh264encdrv.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/jpegdec/user/build-v234ce-gnu-linux-o/libjpegdecdrv.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/sequencer/user/build-v234ce-gnu-linux-o/libseqdrv.a /g/VisionSDK_S32V2_RTM_1_4_0/s32v234_sdk/libs/isp/viu/user/build-v234ce-gnu-linux-o/libviudrv.a
make[3]: Leaving directory '/c/Users/rayle/Documents/MATLAB/codegen/exe/face_detection/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/c/Users/rayle/Documents/MATLAB/codegen/exe/face_detection/build-v234ce-gnu-linux-o'
face_detection.elf | 4 kB | 4.0 kB/s | ETA: 00:03:36 | 0%
face_detection.elf | 871 kB | 871.7 kB/s | ETA: 00:00:00 | 100%
/home/root/data/lbpcascade_frontalface.xml: No such file or directory
/home/root/data/face_detection.png: No such file or directory
Deploying face_detection.elf on 192.168.2.194 ...
./face_detection.elf: error while loading shared libraries: libopencv_calib3d.so.3.4: cannot open shared object file: No such file or directory
Cleaning up, please wait ...
13,251件の閲覧回数
iulianbulancea
In the config structure you have to pass the files needed by the function to run on board. Also, for the advanced examples, the config requires a field called Input, which will be the input of the face_detection function. In your case you can have the following config:
config.MakeJobs = 8;
config.Optimize = true;
config.TargetIpAddress = '10.171.74.173';
config.Deploy = true;
% first entry from the tuple is the name of the file you want to copy to board and is relative to the current path of MATLAB
% second entry from the tuple is name of the file on board and is relative to the elf location
config.ExtraFiles = { ...
{'../../data/face_detection.png', 'data/face_detection.png'}, ...
{'../../data/lbpcascade_frontalface.xml', 'data/lbpcascade_frontalface.xml'}};
params.input = 'Image';
params.file = 'data/face_detection.png';
params.demo = false;
params.KalmanFilter = false;
config.Input = params;
nxpvt_codegen('face_detection.m', config);
Instead of calling the nxpvt_codegen function you can also run the script run_application from the face detection example folder. The script fills in the config structure by asking a list of questions.
Kind regards,
Iulian Bulancea
13,251件の閲覧回数
751301185
Hi,Iulian Bulancea
I have some more questions:When I want to run on a board using CNN,Code generation is not supported for 'mkldnn', 'tensorrt', and 'arm-compute' targets on the  Windows platform.
What's the difference between using MATLAB to develop apex algorithm and using S32DS?
I really hope you can answer for me.
13,249件の閲覧回数
iulianbulancea
You should not define the environmental variable ARM_COMPUTELIB or set it to empty from MATLAB using setenv('ARM_COMPUTELIB'). This way the toolbox will use its one ARM compute library.
Kind regards,
Iulian Bulancea
13,249件の閲覧回数
751301185
Hi,Iulian Bulancea
I am very confused.
13,249件の閲覧回数
iulianbulancea
The toolbox supports code generation for cnn for MATLAB R2018b, R2019a, and R2019b.
Kind regards,
Iulian Bulancea
13,249件の閲覧回数
751301185
Hi,Iulian Bulancea
  nowadays,./face_detection.elf: error while loading shared libraries: libopencv_calib3d.so.3.4: cannot open shared object file: No such file or directory
How should I load this library in MATLAB?
13,249件の閲覧回数
iulianbulancea
You should use the Yocto SD card image provided with Vision SDK 1.4.0.
Kind regards,
Iulian Bulancea
