The code cannot be burned into MPC5744P REV E
6,019件の閲覧回数
ZJoe
As the description contains multiple pictures, please check in the attachment
5,967件の閲覧回数
mariuslucianand
Hello @ZJoe ,
The bootloader image has be flashed before using the RappId BL tool using the S32Design Studio for Power Architecture.
Please check the chapter 2.3 from this document here https://www.nxp.com/docs/en/quick-reference-guide/MBDT-MPC57xx_QSG.pdf
Hope this helps,
Marius
4 返答(返信)
5,996件の閲覧回数
mariuslucianand
Hello @ZJoe ,
Looks like you have there an MPC5744P rev E. This board have a different Serial instance routed to the onboard USB2Serial.
To be able to download the code directly from Simulink on your board, you have to flash another bootloader, the MPC574xP_S32DS_UART0_CAN0_OpenSDA_RevE.rbf
Can you please give this a try?
Marius
5,978件の閲覧回数
ZJoe
Thanks very much, I've found the MPC574xP_S32DS_UART0_CAN0_OpenSDA_RevE.rbf
But it automatically use the other bootloader, which you can see in the attachment.
Could you tell me how to load the MPC574xP_S32DS_UART0_CAN0_OpenSDA_RevE.rbf?
5,968件の閲覧回数
mariuslucianand
Hello @ZJoe ,
Hope this helps,
Marius
5,940件の閲覧回数
ZJoe
I’ve done it, thanks for your patient help.
