S32k144 PiL perf evaluation
2,040 次查看
liu_madeon
Hi talent,
I have the PiL result and try to evaluate Algorithm performance on S32K144,
and my s32k is default pil initialize
how do i know the mcu usage base on tick unit.
Thank you
Sincerely,
标记 (2)
1,956 次查看
constantinrazva
Hello liu.madeon@inventec.com,
Those are profiler ticks that are shown and that means 40MHz clock frequency.
Kind regards,
Razvan.
1,956 次查看
liu_madeon
Hi constantinrazvan.chivu
thank you for your reply asap,
I try to calculate base on this method to know the CPU usage , is work or have any suggestion?
because I got the incredible tiny usage on my module,
0.000798925%(computing usage) =    31957(total function ticks)/40MHz
I try another way to test performance by lauterbach debug tool simple base profilling and got the average usage about 4%
I dont know why such big difference, so I push this question on community and find some probably reason
Thank you
Sincerely,
1,956 次查看
constantinrazva
Hello liu.madeon@inventec.com ,
Sorry for the detailed answer - please take a look at this thread: https://community.nxp.com/thread/535738#comment-1330768 where I propose a way in which you can approximate the CPU load.
Kind regards,
Razvan.
