S32K1xx MATLAB TOOL BOX installation issue: index exceeds array bonds
ソリューションへジャンプ
4,353件の閲覧回数
premch2301
at the last step of verify MBT license: this error is showing that index exceeds array bonds
4,214件の閲覧回数
SorinIBancila
I've sent you a private message. Please check it out.
Sorin Bancila
8 返答(返信)
4,235件の閲覧回数
premch2301
see i think there is some issue with the license file only
4,335件の閲覧回数
premch2301
facing the same problem
タグ(1)
4,312件の閲覧回数
SorinIBancila
I have a clean S32K1xx toolbox installed and I am not able to reproduce your problem. Did you bring any modification the example? What MATLAB version do you use?
From the previous post, I see that you use the S32K1xx v4.3.0? Am I right?
Sorin Bancila
4,301件の閲覧回数
premch2301
while installing MLTBX file, i am facing problem on the last step(verify MBD toolbox license).  due to that it is not installing completely.
MBT version:
4.3.0 Model-Based Design Toolbox for S32K1xx Automotive Microprocessors Family
MATLAB version: R2024b
boot serial no: 92E107F3
license file : (.dat)
#Model-Based Design Toolbox for MATLAB/Simulink - Model-Based Design Toolbox
#for S32K1xx Automotive Microprocessors Family for Prem chanchal Software
#Account
# License for DISK_SERIAL_NUM=92E107F3 laptop
INCREMENT MC_Toolbox_S32K freescale 1.0 26-mar-2045 uncounted \
VENDOR_STRING="Model-Based Design Toolbox for S32K1xx \
Automotive Microprocessors Family" \
HOSTID=DISK_SERIAL_NUM=92e107f3 ISSUER="Freescale \
Semiconductor" ISSUED=02-apr-2025 ck=209 SN="FSL - 16070981" \
TS_OK SIGN="010D EDBB 08E4 D16D 281A 2570 AEB1 3280 2DBC 5852 \
2D0D 3BDF A9F0 32F4 75C3 1DB9 CF8C EE59 7D39 3F0F 61FE BD61 \
6119 AD4D C9B9 EEF8 9348 7117 20FE 82BF"
4,288件の閲覧回数
SorinIBancila
Unfortunately I am unable to reproduce your problem. No matter what I try, I can't get the same error.
In one of your screenshots, I saw that you have multiple S32K1xx toolboxes installed. Please make sure only on in installed.
Can you try these steps, maybe they solve the problem:
1. Revert the MATLAB Path to the Default one.
2. Uninstall all S32K1xx toolboxes. Navigate to the C:\Users\TPEM_USER_1\AppData\Roaming\MathWorks\MATLAB Add-Ons\Toolboxes and delete all NXP_MBDToolbox_S32K1xx folder.
3. Restart MATLAB.
4. Go to Preferences -> MATLAB -> Add-Ons and modify the default installation folder to a shorter path and without including spaces . (e.g. C:\MATLAB\Addons\Toolboxes\R2024B)
5. Inside the MATLAB, navigate to the NXP_MBDToolbox_S32K1xx_4.3.0_20220913.mltbx file and double click on it and install the toolbox.
6. Manually activate the toolbox by copying the license.dat file inside the lic folder.
7. Run the mbd_s32k_path script.
Let me know if these steps solve your problem.
Sorin Bancila
4,242件の閲覧回数
premch2301
i have installed only one S32K1xx add on tool. followed all the above steps.  Still this issue is coming
4,221件の閲覧回数
premch2301
there is something issue with the license file.
4,215件の閲覧回数
SorinIBancila
Sorin Bancila
%3CLINGO-SUB%20id%3D%22lingo-sub-2072663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K1xx%20MATLAB%20TOOL%20BOX%20%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E5%95%8F%E9%A1%8C%3A%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%81%8C%E9%85%8D%E5%88%97%E3%83%9C%E3%83%B3%E3%83%89%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2072663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMBT%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AE%E7%A2%BA%E8%AA%8D%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%3A%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%3CFONT%20color%3D%22%23FF0000%22%3E%3CSTRONG%3E%E3%80%81%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%81%8C%E9%85%8D%E5%88%97%E7%B5%90%E5%90%88%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%3C%2FSTRONG%3E%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2074169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AS32K1xx%20MATLAB%20TOOL%20BOX%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%AE%E5%95%8F%E9%A1%8C%3A%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%81%8C%E9%85%8D%E5%88%97%E3%83%9C%E3%83%B3%E3%83%89%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2074169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9C%E3%81%B2%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%BD%E3%83%AA%E3%83%B3%E3%83%BB%E3%83%90%E3%83%B3%E3%82%B7%E3%83%A9%3C%2FLINGO-BODY%3E
