S32K1XX MBDT SPI clock settings help
724 次查看
ErwinR
I am trying to communicate and configure a TLE8718SA Lowside Switch through SPI communication. In the documentation of that IC it is mentioned that the clock signal has to be continous yet I do not see such an option in the LPSPI configuration block. Is there a way I could manually force the clock signal to be continous?
Cheers
0 回复数
