S32K144 bootloader linker incorrect on some installations
已解决
跳至解决方案
1,796 次查看
gmud1234
I have installed the S32K1xx blockset on my machine. But when targetting the s32k144, I cannot select the 'user' linker file for use with the bootloader - only the linker file for a 148. See images below. How can this be corrected?
1 解答
1,787 次查看
mariuslucianand
Hello @gmud1234,
Please apply the mscripts.zip patch ONLY for the MBDT for S32K1xx 4.2.0 attached in the following post: https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/Read-register-block-error-S32k142/m-p/1...
This behavior will be solved also in a future release of S32K1xx scheduled for this year.
Hope this helps,
Marius
在原帖中查看解决方案
1 回复
1,788 次查看
mariuslucianand
Hello @gmud1234,
Hope this helps,
Marius
