S32K144 Model based design
1,011 次查看
Sriram
Hello ,
I have sine cosine encoders for position sensing for pmsm foc. How do i replace the hall sensor part with the sine cosine encoder sensing part in the pmsm foc example .
Also what other blocks or parameters will be affected if i replace the hall sensor position sensing with sine cosine encoder. How should i estimate speed from the angle obtained from the sine cosine encoder.
I have attached the file which contains the sine cosine encoder model
Thanks for the help.
0 回复数
