Restart PIL Simulation
2,397 次查看
hnkChinaski
I'm doing PIL simulations and everything works fine. However, downloading the application to the board using the RAppID bootloader everytime I rerun a simulation takes a long time.
Is there a way to simply restart the simulation in Simulink without needing to download the same model again to the board?
Thank you
2,310 次查看
hnkChinaski
I don't think the fast restart option helps with my problem. If I rerun a simulation with fast restart activated, the RAppID Bootlader will reflash the application first.
2,369 次查看
patrick_schmid
I'm facing the same issue. Or is there an option to bypass the flashing with the RAppID bootlader, e.g., by use S32 Design Studio to flash the board and "just" run the PiL simulation in Simulink?
Thanks for your answers.
