I am using the Simulink (MATLAB 2018B) with the Model Based Design Toolbox 3.0.0 for MPC5744P target.
I can't generate code due to the following error:
### Build procedure for model: 'ERROR_Example' aborted due to an error.
Failure in mbd_mpc574x_make_rtw: Reference to non-existent field 'info'.Reference to non-existent field 'info'.Component:Simulink | Category:Block diagram error
Please see the example model attached.
Really simple example.
Can you support me why there is this error?
Regards, Rafael
解決済! 解決策の投稿を見る。
Hi rafael.barbosa@chassisbrakes.com,
I can reproduce your error on my side too. It seems to be an exception inside Simulink.
Because the error doesn't say too much about what it caused and I don't have access to the Simulink code to debug it, I can only give you right now a workaround to be able to build the model.
The workaround is to go to Configuration Parameters > Code Generation > Report and uncheck the Static code metrics option.
The static code metrics report is not generated anyway because Simulink fails to parse the compiler's C standard header files, like stdint.h.
I hope this helps you,
Paul
I also tried to install the Model Based Design Toolbox 3.2.0 and the problem persists.
Can you support me with the blocking point?
Kind Regards, Rafael
Do you have some updating on this topic?
It is quite urgent from my side.
Paul
If this is a Simulink issue, please make sure our colleagues at MathWorks are aware. (brianmckay)
Hello Paul,
It worked fine.
This workaround is enough for me.
Thank you very much for the support!
