Problem about on-chip  temperature of  DEVKIT-MPC5744P
haoxue1027
When I ran the program in the DEVKIT-MPC5744P board , I tested the internal temperature of the chip with Tsens1 and refPMC1.
it feels hot when I touch the surface of the chip. It reaches to 60 degrees in the freemaster.
Could you tell me whether the temperature is normal or not.
thank you very much.
best regards
hao
mariuslucianand
Hello [email protected]‌,
On my side, the devkit is running right now at 50*C according to FreeMaster.
But according to the https://www.nxp.com/docs/en/data-sheet/MPC5744P.pdf  MPC5744P Data Sheet this in the normal range.
Hope this helps,
Marius
mariuslucianand
Hope this helps,
Marius
haoxue1027
Hello@marius
thank you very much for answer.
It is very helpful for me .
best regards
hao
