PIL Simulation Error
15,397件の閲覧回数
alimeraj
I am trying to run one of motor control toolbox example code on MPC5744P but when ever i hit the play button I get the following error.
No method 'getComponentBuildInfoPath' with matching signature found for class 'pntpil.MakefileBuilder'.
can you please tell me what is the issue here.
Ali
14,237件の閲覧回数
sundarnatarajan
Hi Daniel,
Thank you very much.. I am able to simulate. The problem is in serial communication.
Sundar
27 返答(返信)
2,299件の閲覧回数
jjacp
Thanks for the hotfix paulvlase. I was also facing the same "ProdEndianess" error as Ali and Sundar.
Also FYI, I also ran into the same error using the MPC5643L MBD Toolbox. I am running 2016b.
2,299件の閲覧回数
alimeraj
Hi Paul,
Thank you very much, I will try it and let you know.
Ali Meraj
2,299件の閲覧回数
alimeraj
I tried this 2017a
2,299件の閲覧回数
paulvlase
Can you post screenshots with "Code Generation" and "Hardware Implementation" (with "Device Details" expanded) sections from Configuration Parameters?
2,299件の閲覧回数
alimeraj
Matlab 2017a config settings
2,299件の閲覧回数
alimeraj
Hi Paul,
I extracted lecture 7 files again and tried to run the model as following:
and it throws the error straight away:
Ali
2,299件の閲覧回数
alimeraj
Hi Paul,
I am using 2014b
Ali
