PIL Simulation Error
alimeraj
I am trying to run one of motor control toolbox example code on MPC5744P but when ever i hit the play button I get the following error.
No method 'getComponentBuildInfoPath' with matching signature found for class 'pntpil.MakefileBuilder'.
can you please tell me what is the issue here.
Ali
sundarnatarajan
Hi Daniel,
Thank you very much.. I am able to simulate. The problem is in serial communication.
Sundar
jjacp
Thanks for the hotfix paulvlase. I was also facing the same "ProdEndianess" error as Ali and Sundar.
Also FYI, I also ran into the same error using the MPC5643L MBD Toolbox. I am running 2016b.
alimeraj
Hi Paul,
Thank you very much, I will try it and let you know.
Ali Meraj
alimeraj
I tried this 2017a
paulvlase
Can you post screenshots with "Code Generation" and "Hardware Implementation" (with "Device Details" expanded) sections from Configuration Parameters?
alimeraj
Matlab 2017a config settings
alimeraj
Hi Paul,
I extracted lecture 7 files again and tried to run the model as following:
and it throws the error straight away:
Ali
alimeraj
Hi Paul,
I am using 2014b
Ali
