Model-Based Design Toolbox compile error in Simulink
1,564 次查看
victor_song_171
I try to use MBDT in matlab ,when build ,error report like below:
Any assistance would be appreciated.
1,490 次查看
constantinrazva
Hello [email protected]‌,
It seems to be a problem due to having a space in the path; it takes as sysroot a different file path (one that does not exist).
To fix this, either delete the space from your path and reinstall the toolbox (to have the correct paths, the new ones), either go to
{Install ROOT}\mbdtbx_s32k14x\mbdtbx_s32k14x
and replace
mbd_s32k14.tmf file
with the one attached here.
This has
TOOL_LIB += -specs=nosys.specs --sysroot="$(TOOL_ROOT)/arm-none-eabi/newlib" -lm
on the 267 line, so now it should contain the correct path, even with the space.
Kind regards,
Razvan.
