Missing elf files while using MBDT generating Code
SmallWhite
Hello,all.
My model is show below,while clicking on  'Generate code and compile model',the code is generated normally, but there is no elf file in the folder.SmallWhite_0-1706277917641.png
At the same time, an error will also be reported:
Error: Encountered an error while compiling 'untitled', as shown in the following image(I turned off the option to only generate code in the settings)
