MPC5744P TPL and CAN issue
Baris
I encountered a few problems in the project I did with the MCP5744p processor;
1. I am trying to communicate with TPL with MC33771 IC, I create the first SPI block as master, but when I choose the second SPI block as slave, it does not allow me to set SCLK and CS pins.
2. I want to read the data sent by the processor via CANBus pins, but the data comes once, stops and I need to reset the board to correct this process.
Would you help me with this topic?
peaces
do you have any results?
