MBDToolboxMPC574xPReleaseV2.0.0
2,263 次查看
742970882
MBDToolboxMPC574xPReleaseV2.0.0 fail to install.MBDToolboxMPC574xPReleaseV2.0.0.jpg
2,015 次查看
mariuslucianand
Thank you for using our toolbox!
Looks like the setup tries to install the toolbox in the "*:\MBDToolbox" path which is not valid.
When installing the toolbox, at the Destination Folder step you can press the Change... button and select a valid path.pastedImage_6.png
If you have any other trouble when you setup our toolbox, please follow this  Video Link : 7692  video.
Hope this helps,
Marius
2,016 次查看
742970882
The above installation process did not occur, but an error occurred directly causing the installation to fail
2,016 次查看
mariuslucianand
The popup message containing Error 1606 appear when you open the setup or after some tabs?
Please have a look on this link https://support.microsoft.com/en-us/help/886549/you-receive-an-error-1606-error-message-when-you-try...  and try applying the solution from here.
Hope this helps,
Marius
