MBDT toolbox using Simulink model module exception
zuozuo
Now using the MBDT tool of S32k3, the top-level model contains the MBDT toolbox module, and the top-level module contains the Simulink model module. Using the subsystem is normal. The model loads the SLX model containing pure algorithms, but there are two issues:
(1) Under each algorithm model, MBDT toolbox driven *. c *. h *. o will be generated, but theoretically speaking, pure algorithm modules do not have these??
(2) Compile all generated code once in S32 ds and report the error shown in the figure (make: * * * No rule to make target'D:/Work/APP.Merge/test260409/s32k3xx_dious32ct_Cnfig/../slprj/ert/_stharedutils/rtwshare d ', needed by' s32k3xx_dious32ct. elf '. Stop)
"make -j8 all" terminated with exit code 2. Build might be incomplete.), What's the reason?
%3CLINGO-SUB%20id%3D%22lingo-sub-2349509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMBDT%20toolbox%20using%20Simulink%20model%20module%20exception%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2349509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENow%20using%20the%20MBDT%20tool%20of%20S32k3%2C%20the%20top-level%20model%20contains%20the%20MBDT%20toolbox%20module%2C%20and%20the%20top-level%20module%20contains%20the%20Simulink%20model%20module.%20Using%20the%20subsystem%20is%20normal.%20The%20model%20loads%20the%20SLX%20model%20containing%20pure%20algorithms%2C%20but%20there%20are%20two%20issues%3A%3CBR%20%2F%3E(1)%20Under%20each%20algorithm%20model%2C%20MBDT%20toolbox%20driven%20*.%20c%20*.%20h%20*.%20o%20will%20be%20generated%2C%20but%20theoretically%20speaking%2C%20pure%20algorithm%20modules%20do%20not%20have%20these%3F%3F%3CBR%20%2F%3E(2)%20Compile%20all%20generated%20code%20once%20in%20S32%20ds%20and%20report%20the%20error%20shown%20in%20the%20figure%20(make%3A%20*%20*%20*%20No%20rule%20to%20make%20target'D%3A%2FWork%2FAPP.Merge%2Ftest260409%2Fs32k3xx_dious32ct_Cnfig%2F..%2Fslprj%2Fert%2F_stharedutils%2Frtwshare%20d%20'%2C%20needed%20by'%20s32k3xx_dious32ct.%20elf%20'.%20Stop)%3CBR%20%2F%3E%22make%20-j8%20all%22%20terminated%20with%20exit%20code%202.%20Build%20might%20be%20incomplete.%EF%BC%89%EF%BC%8C%20What's%20the%20reason%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
