[MBDT,S32 DesignStudio]Code Generation and Configuration for NonAutosar - S32K312 EVB
jyoti_c
I am using MBDT for NXP S32K312.
I see that the S32 configuration available using MBDT is in AutosarMode which is in MCAL layer.(refer image AutosarMode.jpg)
But am working on Bare metal coding in S32Design Studio ( under Drivers)(refer image DriverMode.jpg).
Can you help me know if I can generate code/configure for bare metal coding using MBDT(under Drivers in S32DesignStudio)?
#MBDT #S32K312 #HardwareConfiguration #Non-AUTOSAR
Thanks in Advance
Jyoti C
Tags (2)
stefancinipeanu
Hello @jyoti_c
Unfortunately, Simulink blocks for accessing the S32K3 peripherals in the code generation flow are based on Real-Time Drivers MCAL layer only.  Currently, we do not support code generation on Drivers layer.
Thanks & Regards!
Stefan.
%3CLINGO-SUB%20id%3D%22lingo-sub-2325372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BMBDT%2CS32%20DesignStudio%5DCode%20Generation%20and%20Configuration%20for%20NonAutosar%20-%20S32K312%20EVB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3E%3CBR%20%2F%3EI%20am%20using%20MBDT%20for%20NXP%20S32K312.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3EI%20see%20that%20the%20S32%20configuration%20available%20using%20MBDT%20is%20in%20AutosarMode%20which%20is%20in%20MCAL%20layer.(refer%20image%20AutosarMode.jpg)%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3EBut%20am%20working%20on%20Bare%20metal%20coding%20in%20S32Design%20Studio%20(%20under%20Drivers)(refer%20image%20DriverMode.jpg).%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3ECan%20you%20help%20me%20know%20if%20I%20can%20generate%20code%2Fconfigure%20for%20bare%20metal%20coding%20using%20MBDT(under%20Drivers%20in%20S32DesignStudio)%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%23MBDT%20%23S32K312%20%23HardwareConfiguration%20%23Non-AUTOSAR%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CBR%20%2F%3EThanks%20in%20Advance%3CBR%20%2F%3EJyoti%20C%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2332647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BMBDT%2CS32%20DesignStudio%5DCode%20Generation%20and%20Configuration%20for%20NonAutosar%20-%20S32K312%20EVB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2332647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259746%22%20target%3D%22_blank%22%3E%40jyoti_c%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EUnfortunately%2C%20Simulink%20blocks%20for%20accessing%20the%20S32K3%20peripherals%20in%20the%20code%20generation%20flow%20are%20based%20on%20Real-Time%20Drivers%20MCAL%20layer%20only.%26nbsp%3B%20Currently%2C%20we%20do%20not%20support%20code%20generation%20on%20Drivers%20layer.%3C%2FP%3E%0A%3CP%3EThanks%20%26amp%3B%20Regards!%3C%2FP%3E%0A%3CP%3EStefan.%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
