MBDT: Build Script
MBDT: Build Script
1,322件の閲覧回数
Sam_ECU
How can I edit the build script for MBDT/Simulink as in MCUXpresso below:
1,270件の閲覧回数
Irina_Costachescu
Hi @Sam_ECU
Inside MBDT, you could customize the Simulink model's toolchain by selecting the Specify Build configuration in the Code Generation pane, as illustrated below.
This will allow you to modify flags, commands, and other options necessary for your application.
Could you please try this approach and let us know if it works?
Thank you,
Irina
