MATLAB-NXP MBDT S321XX: License Error: -9
3,487 次查看
Indraja
We have Matlab model which has to be integrated with NXP S321XX toolbox. We followed all the necessary steps and can access the NXP block in our simulink library. But it is showing license activation failed and could not simulate.
PFA,
Thank you
3,456 次查看
Indraja
Can you please help me to fix this problem? We are unable to flash matlab algorithm to NXP hardware?
3,458 次查看
Indraja
Hi Stefan, thanks for the reply. I have given correct Disk serial number but i do not know what is wrong with it.
3,464 次查看
stefancinipeanu
Hi, @Indraja
Usually Error Code -9 means that the license file is correctly attached to the toolbox, but something is wrong with it. Most probably, it is not correctly generated. Did you introduce the correct Disk Serial Number when you generate the license from NXP Software & Licensing website?
Stefan.
