Important question about motor control
1,084 次查看
JonAnder_Amante
I am using the board S32K344MINI-EVB with driver GD3000 and Sunrise motor. I have tested a program where you can manage the speed of motor with the project "S32K344:mc_pmsm_1sh_s32ct". I have different questions because I want to prove new options.
1. I want to use the evaluation board to realize the control of motor, so I want to do the control FOC (2 controllers PI) but I want to simulate the plant (the motor PMSM) and the power electronics (GD3000). In this example, how I can modify it to simulate the plant but continue perfoming the control from the evaluation board? I suppose that I have to change something of state machine block but I don´t know what I have to change.
2. Could you tell me the pins that I am using to send different signals from GD3000 (driver of motor) to motor PMSM? I have information in your website about this but I don´t if that´s the case. I send you a pdf with this information, although it´s not yhe same board I think the pins are the same (INFO_Driver_MOtor.pdf).
Thank you for all,
Jon Ander Amante
5 回复数
971 次查看
stefanvlad
Hi @JonAnder_Amante ,
In order to use the S32K344MINI-EVB, the following modifications are needed on the board:
1. Remove resistors R396 and R397, located on bottom PCB near DC Jack:
2. Populate with 0 (zero) Ohm  resistors R413, R414 and R418 located near J4 connector:
And also because the VDD_HV_A is supplied with 3.3V instead of 5V:
We need to modify the parameters for the Udc and Idc Gains:
%% Application scales
MBD_I_MAX = 20.625;
MBD_U_DCB_MAX = 29.7;
After this we can connect the DEVKIT-MOTORGD (GD3000) board on top of S32K344MINI-EVB:
Now Open FreeMASTER and run the example and check iABC waveforms:
Stefan V.
956 次查看
JonAnder_Amante
Thank you for your reply. At now, I want to realize only the control of FOC in the board "S32K344 MINI-EVB", that is to say, I have another block of the plant that it´s represented the motor PMSM (Sunrise) with power electronics but I have to use the control of FOC with MBD. In this example, could you tell me which block I have to keep and what blocks I have to remove?
I think that I have to keep the current loop and speed loop in the block called "state machine" but the problem is there are many variables and different blocks with different jumps between them.
Basically, my project´s target is to use the same control of FOC from this project but to use another plant.
Thank you for all,
Jon Ander Amante
945 次查看
stefanvlad
I am not sure i understand what other plant you want to use, another motor maybe?
We currently support the Sunrise Motor with parameters in s32k344_mc_pmsm_2sh_s32ct_data.m and Linix Motor with parameters in s32k344_mc_pmsm_2sh_s32ct_data_linix.m
If you have any other motors, you will need to modify the parameters accordingly in data.m files, then do a clean Build.
Have a good day,
Stefan V.
894 次查看
JonAnder_Amante
1. I want to use Sunrise motor with its parameters but my question is if there is any block in SImulink that represents the plant because I want to have a block of the plant on one hand and the controller on the other.
2. Moreover, I send you the parameters of motor Sunrise and I don´t know if you can confirm that the dates are true.
PARAM_Rs = 0.192; % Resistencia del estator [Ohms]
PARAM_Mpp = 2; % Pares de polos [-]
PARAM_Ld = 0.000096; % Inductancia eje D [H]
PARAM_Lq = 0.000107; % Inductancia eje Q [H]
PARAM_Ke = 0.005872; % Constante Back-EMF [V.sec/rad]
PARAM_J = 0.12e-4; % Inercia [kg.m2]
PARAM_r32_F_IP_Wb_motor1 = 0.00518; % Flujo magnetico
%% Parametros diseño LAZO DE CORRIENTE
%Loop Bandwidth = 150 [Hz]
%Loop Attenuation = 1 [-]
%Loop sample time = 0.0001 [sec]
f_cutoff_current = 150; % Frecuencia de corte deseada [Hz]
w0_current = 2 * pi * f_cutoff_current; % Frecuencia natural [rad/s]
xi_current = 0.707; % Amortiguamiento
Ts_current = 1 /fsw; % Tiempo de muestreo
% Cálculos eje D
Kp_D = (2 * xi_current * w0_current * PARAM_Ld) - PARAM_Rs;
Ki_D = (w0_current^2) * PARAM_Ld;
% Cálculos eje Q
Kp_Q = (2 * xi_current * w0_current * PARAM_Lq) - PARAM_Rs;
Ki_Q = (w0_current^2) * PARAM_Lq;
% Current Loop Control (Calculado según NXP GFLIB)
MBD_CLOOP_LIMIT = 0.9;
% Eje D (D-axis)
MBD_D_CC1SC = Kp_D + (Ki_D * Ts_current / 2);
MBD_D_CC2SC = -Kp_D + (Ki_D * Ts_current / 2);
% Eje Q (Q-axis)
MBD_Q_CC1SC = Kp_Q + (Ki_Q * Ts_current / 2);
MBD_Q_CC2SC = -Kp_Q + (Ki_Q * Ts_current / 2);
2. I send you the scheme that I am using in Simulink. My idea is
My idea is to not use the physical motor and to simulate it with the green block you see in the photos. and to perform the control (current loop and speed loop) with the MCLIB blocks.
Thank you for all;
1,037 次查看
dragostoma
Hi, @JonAnder_Amante,
You can find the answer to the initial thread here: missing Motor Control PMSM example in the 1.60 version of the S32K3 MBDT
Dragos
%3CLINGO-SUB%20id%3D%22lingo-sub-2305902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%9C%89%E5%85%B3%E8%BF%90%E5%8A%A8%E6%8E%A7%E5%88%B6%E7%9A%84%E9%87%8D%E8%A6%81%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2305902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%3CSPAN%3E%E5%B8%A6%E9%A9%B1%E5%8A%A8%E5%99%A8%20GD3000%20%E5%92%8C%20Sunrise%20%E7%94%B5%E6%9C%BA%E7%9A%84%20S32K344MINI-EVB%20%E6%9D%BF%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E6%B5%8B%E8%AF%95%E4%BA%86%E4%B8%80%E4%B8%AA%E4%BD%A0%E5%8F%AF%E4%BB%A5%E7%94%A8%E9%A1%B9%E7%9B%AE%20%22%20s32K344%3A%20mc_pmsm_1SH_S32CT%20%22%20%E6%9D%A5%E7%AE%A1%E7%90%86%E7%94%B5%E6%9C%BA%E9%80%9F%E5%BA%A6%E7%9A%84%E7%A8%8B%E5%BA%8F%E3%80%82%E6%88%91%E6%9C%89%E4%B8%8D%E5%90%8C%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E6%83%B3%E8%AF%81%E6%98%8E%E6%96%B0%E7%9A%84%E9%80%89%E6%8B%A9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375465i21E8D42A1779FE60%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JonAnder_Amante_1-1770196663700.png%22%20alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E1%E3%80%82%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%E8%AF%84%E4%BC%B0%E6%9D%BF%E6%9D%A5%E5%AE%9E%E7%8E%B0%E7%94%B5%E6%9C%BA%E7%9A%84%E6%8E%A7%E5%88%B6%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E6%83%B3%E6%8E%A7%E5%88%B6FOC%EF%BC%882%E4%B8%AA%E6%8E%A7%E5%88%B6%E5%99%A8PI%EF%BC%89%EF%BC%8C%E4%BD%86%E6%88%91%E6%83%B3%E6%A8%A1%E6%8B%9F%E5%B7%A5%E5%8E%82%EF%BC%88%E7%94%B5%E5%8A%A8%E6%9C%BAPMSM%EF%BC%89%E5%92%8C%E7%94%B5%E5%8A%9B%E7%94%B5%E5%AD%90%E8%AE%BE%E5%A4%87%EF%BC%88GD3000%EF%BC%89%E3%80%82%E5%9C%A8%E6%AD%A4%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8C%E5%A6%82%E4%BD%95%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E4%BF%AE%E6%94%B9%E4%BB%A5%E6%A8%A1%E6%8B%9F%E5%B7%A5%E5%8E%82%EF%BC%8C%E5%90%8C%E6%97%B6%E7%BB%A7%E7%BB%AD%E6%89%A7%E8%A1%8C%E8%AF%84%E4%BC%B0%E6%9D%BF%E4%B8%8A%E7%9A%84%E6%8E%A7%E5%88%B6%3C%2FSPAN%3E%EF%BC%9F%E6%88%91%E6%83%B3%E6%88%91%E5%BF%85%E9%A1%BB%E6%9B%B4%E6%94%B9%E7%8A%B6%E6%80%81%E6%9C%BA%E6%A8%A1%E5%9D%97%E7%9A%84%E6%9F%90%E4%BA%9B%E9%83%A8%E5%88%86%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E8%A6%81%E6%9B%B4%E6%94%B9%E4%BB%80%E4%B9%88%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E2.%E8%83%BD%E5%90%A6%E5%91%8A%E8%AF%89%E6%88%91%E4%BB%8E%20GD3000%EF%BC%88%E7%94%B5%E6%9C%BA%E9%A9%B1%E5%8A%A8%E5%99%A8%EF%BC%89%E5%90%91%E7%94%B5%E6%9C%BA%20PMSM%20%E5%8F%91%E9%80%81%E4%B8%8D%E5%90%8C%E4%BF%A1%E5%8F%B7%E6%97%B6%E4%BD%BF%E7%94%A8%E7%9A%84%E5%BC%95%E8%84%9A%EF%BC%9F%E6%88%91%E5%9C%A8%E6%82%A8%E7%9A%84%E7%BD%91%E7%AB%99%E4%B8%8A%E7%9C%8B%E5%88%B0%E4%BA%86%E7%9B%B8%E5%85%B3%E4%BF%A1%E6%81%AF%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E6%98%AF%E5%90%A6%E5%B1%9E%E5%AE%9E%E3%80%82%E6%88%91%E7%BB%99%E4%BD%A0%E5%8F%91%E4%BA%86%E4%B8%80%E4%BB%BD%E5%8C%85%E5%90%AB%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E7%9A%84%20pdf%20%E6%96%87%E4%BB%B6%EF%BC%8C%E5%B0%BD%E7%AE%A1%E5%AE%83%E4%B8%8D%E6%98%AF%E5%90%8C%E4%B8%80%E4%B8%AA%E6%9D%BF%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E5%A4%A7%E5%A4%B4%E9%92%88%E6%98%AF%E4%B8%80%E6%A0%B7%E7%9A%84%20(INFO_Driver_MOtor.pdf)%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E5%A4%A7%E5%AE%B6%E3%80%81%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EJon%20Ander%20Amante%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2313837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Important%20question%20about%20motor%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2313837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226147%22%20target%3D%22_blank%22%3E%40JonAnder_Amante%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%AD%A4%E5%A4%84%E6%89%BE%E5%88%B0%E5%88%9D%E5%A7%8B%E4%B8%BB%E9%A2%98%E7%9A%84%E7%AD%94%E6%A1%88%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2Fmissing-Motor-Control-PMSM-example-in-the-1-60-version-of-the%2Fm-p%2F2313448%2Fhighlight%2Ftrue%23M10626%22%20target%3D%22_blank%22%3ES32K3%20MBDT%201.60%20%E7%89%88%E6%9C%AC%E4%B8%AD%E7%BC%BA%E5%B0%91%E7%94%B5%E6%9C%BA%E6%8E%A7%E5%88%B6%20PMSM%20%E7%A4%BA%E4%BE%8B%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%BE%B7%E6%8B%89%E5%8F%A4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2316523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Important%20question%20about%20motor%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2316523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%98%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226147%22%20target%3D%22_blank%22%3E%40JonAnder_Amante%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%B8%BA%E4%BA%86%E4%BD%BF%E7%94%A8%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FS32K344MINI-EVB%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32K344MINI-EVB%3C%2FA%3E%EF%BC%8C%E9%9C%80%E8%A6%81%E5%9C%A8%E6%9D%BF%E4%B8%8A%E8%BF%9B%E8%A1%8C%E4%BB%A5%E4%B8%8B%E4%BF%AE%E6%94%B9%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1770819182442.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1770819182442.png%22%20style%3D%22width%3A%20850px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1770819182442.png%22%20style%3D%22width%3A%20850px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1770819182442.png%22%20style%3D%22width%3A%20850px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1770819182442.png%22%20style%3D%22width%3A%20850px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376521iE9EA517CF495AD10%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1770819182442.png%22%20alt%3D%22stefanvlad_0-1770819182442.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E1.%E5%8F%96%E4%B8%8B%20PCB%20%E5%BA%95%E9%83%A8%E9%9D%A0%E8%BF%91%E7%9B%B4%E6%B5%81%E6%8F%92%E5%AD%94%E7%9A%84%E7%94%B5%E9%98%BB%E5%99%A8%3CSTRONG%3ER396%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3ER397%3C%2FSTRONG%3E%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_4-1770819788524.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1770819788524.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1770819788524.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1770819788524.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1770819788524.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376529i8EB250BFC515F804%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_4-1770819788524.png%22%20alt%3D%22stefanvlad_4-1770819788524.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2.%E5%9C%A8%20J4%20%E8%BF%9E%E6%8E%A5%E5%99%A8%E9%99%84%E8%BF%91%E8%A3%85%E5%85%A5%200%3CSTRONG%3E%EF%BC%88%E9%9B%B6%3C%2FSTRONG%3E%EF%BC%89%E6%AC%A7%E5%A7%86%E7%94%B5%E9%98%BB%3CSTRONG%3ER413%3C%2FSTRONG%3E%E3%80%81%3CSTRONG%3ER414%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3ER418%20%3C%2FSTRONG%3E%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_3-1770819728806.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1770819728806.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1770819728806.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1770819728806.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1770819728806.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376527iA7C8E7C849E35ABB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_3-1770819728806.png%22%20alt%3D%22stefanvlad_3-1770819728806.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E4%B9%9F%E6%98%AF%E5%9B%A0%E4%B8%BA%20VDD_HV_A%20%E7%9A%84%E7%94%B5%E5%8E%8B%E4%B8%BA%203.3V%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%205V%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_2-1770819465940.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1770819465940.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1770819465940.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1770819465940.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1770819465940.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376524i09EFFBC617C5A3C4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_2-1770819465940.png%22%20alt%3D%22stefanvlad_2-1770819465940.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%20Udc%20%E5%92%8C%20Idc%20%E5%A2%9E%E7%9B%8A%E5%8F%82%E6%95%B0%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_6-1770820165900.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_6-1770820165900.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_6-1770820165900.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_6-1770820165900.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_6-1770820165900.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376533iD0B6B26893B98002%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_6-1770820165900.png%22%20alt%3D%22stefanvlad_6-1770820165900.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22rtcContent%22%3E%0A%3CDIV%20class%3D%22lineNode%22%3E%3CSPAN%3E%25%25%20%E5%BA%94%E7%94%A8%E8%A7%84%E6%A8%A1%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lineNode%22%3E%3CSPAN%3Embd_i_max%20%3D%2020.625%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lineNode%22%3E%3CSPAN%3Embd_u_dcb_max%20%3D%2029.7%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lineNode%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lineNode%22%3E%3CSPAN%3E%E4%B9%8B%E5%90%8E%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E5%B0%86%20DEVKIT-MOTORGD%20(GD3000)%20%E6%9D%BF%E8%BF%9E%E6%8E%A5%E5%88%B0%20S32K344MINI-EVB%20%E7%9A%84%E9%A1%B6%E9%83%A8%EF%BC%9A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lineNode%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_5-1770819975008.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_5-1770819975008.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_5-1770819975008.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_5-1770819975008.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_5-1770819975008.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376530iD9521C936A58AEE3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_5-1770819975008.jpeg%22%20alt%3D%22stefanvlad_5-1770819975008.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%8E%B0%E5%9C%A8%E6%89%93%E5%BC%80%20FreeMASTER%EF%BC%8C%E8%BF%90%E8%A1%8C%E7%A4%BA%E4%BE%8B%E5%B9%B6%E6%A3%80%E6%9F%A5%20iABC%20%E6%B3%A2%E5%BD%A2%EF%BC%9A%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_7-1770821519787.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_7-1770821519787.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_7-1770821519787.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_7-1770821519787.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_7-1770821519787.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376534iB675226DFEEF715E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_7-1770821519787.png%22%20alt%3D%22stefanvlad_7-1770821519787.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2316910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Important%20question%20about%20motor%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2316910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%AD%94%E5%A4%8D%E3%80%82%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%88%91%E5%8F%AA%E6%83%B3%E5%9C%A8%E6%9D%BF%E4%B8%AD%E5%AE%9E%E7%8E%B0%E5%AF%B9%20FOC%20%E7%9A%84%E6%8E%A7%E5%88%B6%20%22%20S32K344%20MINI-EVB%20%22%EF%BC%8C%E4%B9%9F%E5%B0%B1%E6%98%AF%E8%AF%B4%EF%BC%8C%E6%88%91%E8%BF%98%E6%9C%89%E5%8F%A6%E4%B8%80%E4%B8%AA%E6%96%B9%E5%9D%97%E5%AE%83%E4%BB%A3%E8%A1%A8%E5%B8%A6%E6%9C%89%E7%94%B5%E5%8A%9B%E7%94%B5%E5%AD%90%E8%AE%BE%E5%A4%87%E7%9A%84%E7%94%B5%E6%9C%BA%20PMSM%EF%BC%88Sunrise%EF%BC%89%EF%BC%8C%E4%BD%86%E6%88%91%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20MBD%20%E7%9A%84%20FOC%20%E6%8E%A7%E5%88%B6%E3%80%82%E5%9C%A8%E8%BF%99%E4%B8%AA%E4%BE%8B%E5%AD%90%E4%B8%AD%EF%BC%8C%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E5%93%AA%E4%BA%9B%E5%8C%BA%E5%9D%97%E5%BF%85%E9%A1%BB%E4%BF%9D%E7%95%99%EF%BC%8C%E5%93%AA%E4%BA%9B%E5%8C%BA%E5%9D%97%E5%BF%85%E9%A1%BB%E5%88%A0%E9%99%A4%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JonAnder_Amante_0-1770883302148.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_0-1770883302148.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_0-1770883302148.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_0-1770883302148.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376633iCDB15E67391B9421%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JonAnder_Amante_0-1770883302148.png%22%20alt%3D%22JonAnder_Amante_0-1770883302148.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E5%BF%85%E9%A1%BB%E5%B0%86%E5%BD%93%E5%89%8D%E5%BE%AA%E7%8E%AF%E5%92%8C%E9%80%9F%E5%BA%A6%E5%BE%AA%E7%8E%AF%E4%BF%9D%E7%95%99%E5%9C%A8%E5%90%8D%E4%B8%BA%22state%20machine%22%20%E7%9A%84%E5%9D%97%E4%B8%AD%EF%BC%8C%E4%BD%86%E9%97%AE%E9%A2%98%E6%98%AF%E6%9C%89%E8%AE%B8%E5%A4%9A%E5%8F%98%E9%87%8F%E5%92%8C%E4%B8%8D%E5%90%8C%E7%9A%84%E5%9D%97%EF%BC%8C%E5%AE%83%E4%BB%AC%E4%B9%8B%E9%97%B4%E6%9C%89%E4%B8%8D%E5%90%8C%E7%9A%84%E8%B7%B3%E8%BD%AC%E3%80%82%20%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JonAnder_Amante_1-1770883826681.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770883826681.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770883826681.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770883826681.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376636i5060B73E4FB4463C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JonAnder_Amante_1-1770883826681.png%22%20alt%3D%22JonAnder_Amante_1-1770883826681.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9F%BA%E6%9C%AC%E4%B8%8A%EF%BC%8C%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E7%9B%AE%E6%A0%87%E6%98%AF%E4%BD%BF%E7%94%A8%E4%B8%8E%E6%9C%AC%E9%A1%B9%E7%9B%AE%E7%9B%B8%E5%90%8C%E7%9A%84%20FOC%20%E6%8E%A7%E5%88%B6%EF%BC%8C%E4%BD%86%E4%BD%BF%E7%94%A8%E5%8F%A6%E4%B8%80%E4%B8%AA%E5%B7%A5%E5%8E%82%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%E5%A4%A7%E5%AE%B6%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EJon%20Ander%20Amante%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2317212%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Important%20question%20about%20motor%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317212%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%98%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226147%22%20target%3D%22_blank%22%3E%40JonAnder_Amante%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E4%B8%8D%E5%A4%AA%E6%98%8E%E7%99%BD%E4%BD%A0%E8%BF%98%E6%83%B3%E7%94%A8%E4%BB%80%E4%B9%88%E8%AE%BE%E5%A4%87%EF%BC%8C%E4%B9%9F%E8%AE%B8%E6%98%AF%E5%8F%A6%E4%B8%80%E4%B8%AA%E5%8F%91%E5%8A%A8%E6%9C%BA%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E7%9B%AE%E5%89%8D%E6%94%AF%E6%8C%81%3CSTRONG%3ESunrise%20%E7%94%B5%E6%9C%BA%3C%2FSTRONG%3E%EF%BC%88%E5%8F%82%E6%95%B0%E8%A7%81%3CSTRONG%3Es32k344_mc_pmsm_2sh_s32ct_data%3C%2FSTRONG%3E%3CSTRONG%3E.%3C%2FSTRONG%3Em%EF%BC%89%E5%92%8C%20Linix%20%E7%94%B5%E6%9C%BA%EF%BC%88%E5%8F%82%E6%95%B0%E8%A7%81%20s32k344_mc_pmsm_2sh_s32ct_data_linix.m%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E9%A9%AC%E8%BE%BE%EF%BC%8C%E5%88%99%E9%9C%80%E8%A6%81%E7%9B%B8%E5%BA%94%E5%9C%B0%E4%BF%AE%E6%94%B9data.m%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%E5%8F%82%E6%95%B0%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BF%9B%E8%A1%8C%E5%85%A8%E6%96%B0%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E4%BD%A0%E6%84%89%E5%BF%AB%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2318452%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Important%20question%20about%20motor%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2318452%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E1.%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%E5%B8%A6%E5%8F%82%E6%95%B0%E7%9A%84%20Sunrise%20%E7%94%B5%E6%9C%BA%EF%BC%8C%E4%BD%86%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8CSImulink%20%E4%B8%AD%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%A3%E8%A1%A8%E5%B7%A5%E5%8E%82%E7%9A%84%E6%A8%A1%E5%9D%97%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E6%83%B3%E4%B8%80%E6%96%B9%E9%9D%A2%E6%9C%89%E5%B7%A5%E5%8E%82%E6%A8%A1%E5%9D%97%EF%BC%8C%E5%8F%A6%E4%B8%80%E6%96%B9%E9%9D%A2%E6%9C%89%E6%8E%A7%E5%88%B6%E5%99%A8%E6%A8%A1%E5%9D%97%E3%80%82%20%3C%2FP%3E%3CP%3E2.%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%88%91%E5%90%91%E6%82%A8%E5%8F%91%E9%80%81%E4%BA%86%20%22%E9%A9%AC%E8%BE%BE%E6%97%A5%E5%87%BA%20%22%E7%9A%84%E5%8F%82%E6%95%B0%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E6%82%A8%E6%98%AF%E5%90%A6%E8%83%BD%E7%A1%AE%E8%AE%A4%E8%BF%99%E4%BA%9B%E6%97%A5%E6%9C%9F%E6%98%AF%E7%9C%9F%E5%AE%9E%E7%9A%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EPARAM_Rs%20%3D%200.192%3B%25%20Resistencia%20del%20estator%20%5BOhms%5D%20%E7%94%B5%E9%98%BB%E5%99%A8%5B%E6%AC%A7%E5%A7%86%5D%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EPARAM_Mpp%20%3D%202%3B%25%20Pares%20de%20polos%20%5B-%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EPARAM_Ld%20%3D%200.000096%3B%25%20Inductancia%20eje%20D%20%5BH%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EPARAM_Lq%20%3D%200.000107%3B%25%20Inductancia%20eje%20Q%20%5BH%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3Eparam_ke%20%3D%200.005872%3B%25%20%E6%81%92%E5%AE%9A%E5%8F%8D%E7%94%B5%E5%8A%A8%E5%8A%BF%20%5Bv.sec%2Frad%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EPARAM_J%20%3D%200.12e-4%3B%25%20Inercia%20%5Bkg.m2%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EPARAM_r32_F_IP_Wb_motor1%20%3D%200.00518%3B%25%20Flujo%20magnetico%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25%25%20%E8%AE%BE%E8%AE%A1%E5%8F%82%E6%95%B0%20LAZO%20DE%20CORRIENTE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25%E7%8E%AF%E8%B7%AF%E5%B8%A6%E5%AE%BD%20%3D%20150%20%5BHz%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25%E7%8E%AF%E8%B7%AF%E8%A1%B0%E5%87%8F%20%3D%201%20%5B-%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25Loop%20%E9%87%87%E6%A0%B7%E6%97%B6%E9%97%B4%20%3D%200.0001%20%5B%E7%A7%92%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25-----------------------------------------------------%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3Ef_cutoff_current%20%3D%20150%3B%25%20Frecuencia%20de%20corte%20deseada%20%5BHz%5D%20(%E5%85%B3%E6%96%AD%E7%94%B5%E6%B5%81)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3Ew0_current%20%3D%202%20*%20pi%20*%20f_cutoff_current%3B%25%20%E8%87%AA%E7%84%B6%E9%A2%91%E7%8E%87%5Brad%2Fs%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3Exi_current%20%3D%200.707%3B%25%20Amortiguamiento%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3ETs_current%20%3D%201%20%2Ffsw%3B%25%20Tiempo%20de%20muestreo%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25%20C%C3%A1lculos%20eje%20D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EKp_D%20%3D%20(2%20*%20xi_current%20*%20w0_current%20*%20PARAM_Ld)%20-%20PARAM_Rs%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EKi_D%20%3D%20(w0_current%5E2)%20*%20PARAM_Ld%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25%20%E8%AE%A1%E7%AE%97%20Q%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EKp_Q%20%3D%20(2%20*%20xi_current%20*%20w0_current%20*%20PARAM_Lq)%20-%20PARAM_Rs%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EKi_Q%20%3D%20(w0_current%5E2)%20*%20PARAM_Lq%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25%20%E7%94%B5%E6%B5%81%E7%8E%AF%E6%8E%A7%E5%88%B6%EF%BC%88%E6%A0%B9%E6%8D%AE%20NXP%20GFLIB%20%E8%AE%A1%E7%AE%97%EF%BC%89%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25----------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3Embd_cloop_limit%20%3D%200.9%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25%20Eje%20D%EF%BC%88D%20%E8%BD%B4%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EMBD_D_CC1SC%20%3D%20Kp_D%20%2B%20(Ki_D%20*%20Ts_current%20%2F%202)%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EMBD_D_CC2SC%20%3D%20-Kp_D%20%2B%20(Ki_D%20*%20Ts_current%20%2F%202)%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25%20Eje%20Q%EF%BC%88Q%20%E8%BD%B4%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EMBD_Q_CC1SC%20%3D%20Kp_Q%20%2B%20(Ki_Q%20*%20Ts_current%20%2F%202)%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EMBD_Q_CC2SC%20%3D%20-Kp_Q%20%2B%20(Ki_Q%20*%20Ts_current%20%2F%202)%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CP%3E2.%E6%88%91%E6%8A%8A%E5%9C%A8%20Simulink%20%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%E6%96%B9%E6%A1%88%E5%8F%91%E7%BB%99%E4%BD%A0%E3%80%82%E6%88%91%E7%9A%84%E6%83%B3%E6%B3%95%E6%98%AF%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JonAnder_Amante_1-1771229540348.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1771229540348.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376908i66C9513943847B05%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JonAnder_Amante_1-1771229540348.png%22%20alt%3D%22JonAnder_Amante_1-1771229540348.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JonAnder_Amante_2-1771229553893.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_2-1771229553893.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376909i5A97B7E58B87D855%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JonAnder_Amante_2-1771229553893.png%22%20alt%3D%22JonAnder_Amante_2-1771229553893.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JonAnder_Amante_4-1771229596623.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_4-1771229596623.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376911iF3EEAB279A38539B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JonAnder_Amante_4-1771229596623.png%22%20alt%3D%22JonAnder_Amante_4-1771229596623.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JonAnder_Amante_3-1771229577117.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_3-1771229577117.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376910iA5F1CE9D7CE36E11%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JonAnder_Amante_3-1771229577117.png%22%20alt%3D%22JonAnder_Amante_3-1771229577117.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E6%83%B3%E6%B3%95%E6%98%AF%E4%B8%8D%E4%BD%BF%E7%94%A8%E5%AE%9E%E4%BD%93%E7%94%B5%E6%9C%BA%EF%BC%8C%E8%80%8C%E6%98%AF%E7%94%A8%E7%85%A7%E7%89%87%E4%B8%AD%E7%9A%84%E7%BB%BF%E8%89%B2%E5%9D%97%E6%9D%A5%E6%A8%A1%E6%8B%9F%E5%AE%83%E3%80%82%E5%B9%B6%E9%80%9A%E8%BF%87%20MCLIB%20%E5%9D%97%E6%89%A7%E8%A1%8C%E6%8E%A7%E5%88%B6%EF%BC%88%E7%94%B5%E6%B5%81%E7%8E%AF%E5%92%8C%E9%80%9F%E5%BA%A6%E7%8E%AF%EF%BC%89%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E5%A4%A7%E5%AE%B6%EF%BC%9B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
